P500 Picked up my 520 today, leaking oil.
Mortdog
Minnesota
Just picked up today. Drove it 20 miles total so far. Stopped by my local upholstery shop to see about a cover for the machine. Noticed when I left. A oil spot in his driveway. It’s definitely coming from the engine. Seems like it’s coming from high up on the engine. From what I can see. I checked the quantity and it’s in the middle of the cross hatch. But, it’s a definite leak. Headed back to the dealer. Other than that. 1st impression is great. It definitely takes the small bumps smoother than my old 2015 p500. Big bumps are still rough. No complaints on the automatic transmission. Reading other posts. I was expecting shifts that were harsh and at the wrong time. I’m not noticing that at all. It’s been perfect! On a flat road , or up or down steep hills. It also starts instantly with no hesitation. I’m surprised on the oil leak, because it’s a Honda. I’ll report back the findings.
C481D36B DD38 4DD3 80B8 432301B17A05 9118B004 0170 4CDE 8EBE 2FC945AFB930 FE6F2932 A373 43CD 93E3 D2C56851A05F 0DD082B9 EDE0 4BD0 A7DC D3F853CFF0EF
ehart814
ehart814
1,654
3,643
NWPA
That's a new one. I'm sure they will get you fixed up. I bought a 500 in early 16 and it ended up getting a leak at the front differential. There were a few that did this. It was a very simple fix. I believe an o-ring was not properly installed when it was assembled. They fixed it up no problem and I never had another issue.
Mortdog
Minnesota
That is unusual, are you sure the dealer just didn't spill it all over or over fill it?
No, it was clean as a whistle when I picked it up. I’m going to remove this access panel after breakfast to see if I can see the top better. The leak looks like it’s high and running down. It’s definitely not the front or real differential. I’m also going to follow the manual on checking proper oil level. Maybe they over serviced it? Not sure.. But it does say not to screw the dipstick back in for the level check.
1EC06666 193E 4D7A AB53 50CDEF382663 FAA15FD6 CFF3 4D73 A165 EB7558684B41 E488F473 21A7 4A81 AD2F 3C182BC188E1
P
pappyo
593
2,380
Welcome from Central N.Y
BUMMER on the leak - Good You Spotted Before Major damage.
Patience will prevail.
Red is the 1st. Color - All other colors followed hopping to Cling onto some of the Glory - ( Honda hopes they sell )
Jerryg
Jerryg
10,916
88,013
NEPA
View attachment 261702 View attachment 261703 View attachment 261704
Yes, that is correct about the dipstick.
I am not familiar with that engine but, I certainly would check the oil level and the breather, before I let a dealer get involved.
Mortdog
Minnesota
Found it!!! You can see this electrical harness not seated correctly in the engine case halves. R/H side on top of the engine case below the throttle body.(I’m pointing to it with a long screwdriver in the 1st picture). It was exactly 1 qt low on oil after 20 miles of driving. I would say the oil is splashing out when the machine is hitting bumps. Because with it idling I don’t see it pouring out oil. On another unrelated quality control note. This wire harness looks like it’s supposed to go under the seat pan covers.
I’ll take it back to the dealer and see what Honda wants to do.
98A62526 5838 4DD6 AB77 82B9711A4B93 E6F055E4 E2A9 44DF B0E5 98B6C25B08C3 F92DD3BF 5F41 459F 86A2 CD993E3904B1 A054BBAC 892D 41CC 8823 A5599E30C83E
Jerryg
Jerryg
10,916
88,013
NEPA
View attachment 261726 View attachment 261727 View attachment 261728 View attachment 261729
That is very un-Honda like.
So, do you try to get that seal back in there with dull screwdriver or do you split the casing?
HondaTech
Thats for the stator wiring, most likely the flywheel behind that cover is slinging oil as it spins and blowing it right out of the hole.
Its stuff like this we dont think to look for, but we'll definitely keep an eye out for this from now on.
monaco
monaco
371
963
Indiana
bit.ly
Yeah that leak is surprising. Congrats on the new machine
F
Fischer
209
321
The woods
Seriously, what is up with honda now? I've been reading more and more about issues with 500, now 520, 700 and alot on 1000s. Total honda person, however, it's all starting to make me wonder? I get it, we are all honda folks, but man, I can see why folks are trying different brands.
Reactions: Mudder
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Bummer for you and hope the fix/cure doesn't turn into a nightmare.
107,956
Its been this way the last 8-10 yrs or so with alot of things, production, trades etc. Its not just Honda. Cheap labor as one, people going to fast and 1/2 the time giving 0 Fucx’s about how they do there jobs. Its generation thing imo. I deal with it every day in my trade it sucks and it worries me.
Forums always show 75% of the time the negatives cuz people are looking for answers as they should be cuz thats what were here for. So it highlights all issues.
As for the OP, glad you found the problem. Now just needs to get fixed so u can get back out there and ride 🤟
HondaTech
Couple that with production lines being hammered due to the Scamdemic and its been a rough year for sure.
107,956
Yes, that hasnt helped either. Just escalates the issues.
Reactions: Mudder
hondabob
1,163
4,538
Prescott Valley, AZ
That rubber seal gets sealant so it needs to be cleaned up real good and the case may need to be removed to do it right. That area will seep oil with the miles, usually at 5,000 miles or more. All of my Pioneers and Talons seep oil there so I just clean it up a every oil change.
42,121
My 700 oozed a bit from there from the start (although it was properly seated). I did the trailer park fix by lifting the edges and adding a bit of RTV. Not worth pulling the cover for unless it returns.
Come to think of it, my old 450S would also seep just enough to hold dust from the stator wiring.
Reactions: Jerryg
