PIONEER 1000-5 CONVERTIBLE CAB ENCLOSURE DOORS
SuperATV
SuperATV
1,236
8,601
Madison, IN
www.superatv.com
PIONEER 1000-5 CONVERTIBLE CAB ENCLOSURE DOORS​
Link: https://www.superatv.com/honda-pioneer-1000-5-convertible-cab-enclosure-doors
  • Removable top half for increased airflow
  • Made with lightly tinted 1/4” polycarbonate
  • XR Optic Hard Coating adds unmatched scratch resistance
  • Frame constructed of powder-coated carbon steel
  • Seals tight with Secure Seal technology
  • Includes sliding windows and bolt-on side-view mirrors
  • Lockable latches are easy to open and close
  • Honda Pioneer 1000-5 : 2016+
Honda pioneer 1k doors 01
Honda pioneer 1k doors 02
Honda pioneer 1k doors 03
Honda pioneer 1k doors 05
Year-Round Riding
Boom. Did you hear that? Thunder—the rain clouds are moving in, and you're thirty minutes from any sheltered area. Don't let Mother Nature catch you unprepared. Install SuperATV's Honda Pioneer 1000-5 Convertible Cab Enclosure Doors instead. With little effort, you can transform them from full doors to half doors. You'll be able to keep up with your work without worrying about the weather. They're made from lightly-tinted polycarbonate material so that you can stay protected from all the elements on the trail. These doors are one-of-a-kind, featuring our two-piece design and loaded with features.
Sealed Tight with Secure Seal Technology
Thanks to our Secure Seal technology, you can keep the weather where it belongs—outside your cab. We use a full-length bulb seal and powerful gas struts to keep the doors snug to the frame of your machine. So not only is your cab leak-proof, but you also get a rattle-free ride.
Convert from a Full Door to Half Door
Preparing for the trail and the elements can save you a lot of trouble. And these doors do just that. You can switch from a full door to a half door when you want more airflow than what a window can give you. It's simple: remove the bolts from the bottom portion of the door and unhook the gas strut. The half door sits low enough to rest your arm on its frame but still high enough to protect you from trail debris. And if our half-door concept isn't open enough, you can remove it too for that open-cab feel.
Made with Scratch-Resistant Polycarbonate
We've seen what rough terrain can do to your rig—we don't want to see what it can do to you. That's why we made these doors with our lightly-tinted polycarbonate material. It's 25 times stronger than acrylic and 250 times stronger than glass. And that's not all—we treated them with our proprietary XR Optic Hard Coating for added durability against scratches, abrasions, and harmful UV rays. Plus, we've made the frame from powder-coated steel tubing so that these doors will last.
Loaded with Convenient Features
We took these doors to the next level. They're cleverly designed for better protection and to control your cab's comfort level. We also loaded these doors with accessories. They come with side-view mirrors, expanding your visibility and making your ride safer. Our key-locking latches add extra security to your machine, while the secure gas struts make them easier to open and close. And if that wasn't enough, installation is super easy. You'll have these doors installed on your machine and will be riding the trails before you know it.
