Pioneer 1000 not going into gear.
Mabrie1000
Hello everyone. New to this site. Looking for some help with my 1000. Parked in around 7 months ago for the winter, started if a few times to keep it fresh. Tried to start it yesterday, battery dead. Jumped it with s charger. Runs ok but won't go into any gear. Ran fine when Parked. Wondering if anyone has any idea. Thank you for looking.
Mabrie1000
Hello everyone. New to this site. Looking for some help with my 1000. Parked in around 7 months ago for the winter, started if a few times to keep it fresh. Tried to start it yesterday, battery dead. Jumped it with s charger. Runs ok but won't go into any gear. Ran fine when Parked. Wondering if anyone has any idea. Thank you for looking. Always had it serviced by honda dealer.
  • Haha
Reactions: Remington
107,302
What year P1? Is it a 3or5?
Also need pics of the rig to start off so we know your not a Poo Poo infiltrator. Youve been here since 21’ so u should know.
Pics Or It Didnt happen!
Welcome from Michigan BTW
Get a new battery, the DCT needs a fully charged well working system to operate. Also check your grounds and make sure no mice have chewed them.
Scoop
Scoop
4,239
15,883
  3. Talon R LV
^^ This. Poor grounds and bad batteries are the DCT's nemesis.
If you don't keep a proper battery maintainer or fully charge the battery at least monthly when storing for that long, you're going to have longevity issues with vehicle batteries. Starting and running for 15 minutes every couple months will NOT help.
Further, if you don't run it to full operating temperature when you DO start it every other month, you're actually hurting the engine (moisture must be heated out).
If storing that long, disconnect or remove the battery (for charging). All it takes is even the smallest parasitic drain and its gonna ruin a good battery.
Mabrie1000
Getting ready for the 4th of July parade. Thanks for all the info. Put innee battery and walla, it worked. Shifts fine. Thank you everyone for your help. Have a safe and happy 4th.
20210703 084521 20210703 084530
