P500 Pioneer 500 - The good, the bad, and the ugly
sarc201
sarc201
15
5
Dayton, Ohio
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,316
84,065
Don't really understand why they made it so hard to put into reverse. Just a Honda thing I guess. Mine won't go to neutral, let alone reverse, unless it standing still. There's absolutely no reason for the reverse lever
Agree, adjusting the cable to never pull it again an easy fix to a complicated design..Hope the engineer that designed it knows his work was eliminated with a turn of a nut. Ditch the expense of the pull lever and add a glove box instead.
lee
lee
Village Idiot
2,331
13,072
Springfield Ohio
Have to wonder if that engineer doesn't smile to himself every time some one 'discovers' how to do this knowing his design meets the requirement to have a two motion engagement for reverse while also providing a way for the people using the system to be a little bit more satisfied with there p500.
I think vehicles that create long term satisfaction are why I keep returning to Honda again and again.
Mudder
Mudder
11,316
84,065
Did the reverse delete to mine this weekend. Best 10 minute mod I've done on my P500 and definitely the cheapest.
Seat belt speed limiter delete by removing a internal buckle piece is another good freebie for in/out chores on the property.
CamoP500
89
177
Lake Vermilion
The seat belt delete will probably happen. Though I like the fact when the kids use it they have to buckle up to go faster than 14. If it were just me it would be done.
Reactions: Mudder and monaco
futzin
futzin
3,141
22,593
Kentucky
STILL need to do this one...
Reactions: monaco
NTCPrezJB
NTCPrezJB
President of #NTC
100,421
897,533
Canton, OH
You can wire a seat belt limiter delete to a hidden switch. ;)
HUCK
HUCK
1,047
2,314
ARIZONA
OK ! The good , everything . If you did your research and bought a P5 for what it is , it is an awesome little machine !
OK ! The bad , They ride ruff and aren't comfortable . If you did your research , you new this going in .
OK ! The ugly , They aren't pretty .
I have a RZR 900 trail (50") , A Talon X , and the Pioneer 500 in my SXS collection . The Pioneer gets used most often , partially because all the trails out my back door are 50'' trails BUT it is just a lot of fun .
41,758
Are you smiling?
I actually don't/didn't have an issue with the reverse setup. But I don't plow either.
I'm actually OK with the looks. New 520 even more so.
34,174
Honda said they're going to continue to make the 500 but, if I read it correctly, it'll only be available in red.
Just wondering if that would fall under good, bad or ugly? 🥣😁
Being their most bulletproof, seems they would always keep it on the lineup....👍
Reactions: trigger and monaco
P
pappyo
593
2,377
RED Honda's have always had the most POWER & DEPENDABILITY.
One of the many reasons we buy Honda (Red & the other colors )
All the other colors came later & hopping some of the Red glory rubs off & ( Sells )
That's why we buy & accessorize to our individual Liking , Wants & Needs.
Reactions: Mudwing and monaco
