P1000 PIONEER DYING WHEN PUT IN GEAR
A
Aaron_
22
38
Florida
Ok. Here to help. SAME EXACT PROBLEM as OP had. 2016 Pioneer 1005-5. Installed new battery, no change. I babied it and got it to run up and down the road sounding sickly. Stopped and over and over same issue. Go to park it overnight while I research. Now I smell a faint burning smell. Look down behind the machine….there it is. Red Hot muffler. Literally, see pic
51676BC0 BC96 4084 91E9 EA973F7159B8
Jerryg
Jerryg
10,954
88,230
NEPA
That is no bueno, lean condition?
A
Aaron_
22
38
Florida
Not sure, but it makes sense that its not breathing as I could not get the RPMs high after feathering to start and driving around. I do seem to remember Honda sending out a recall on this issue. Should have listened! Ha ha! It’s a 2016 1000-5 with 230 hours and 1700 miles. I was starting to think water in the fuel but looks like I was a bit off on that guess.
EA60E74E A76D 432C B139 D8D5A348C9C9
Jerryg
Jerryg
10,954
88,230
NEPA
That doesn't answer why the muffler is getting so hot, it could be a lean fuel issue which could ruin the engine. I would get it straightend out befor riding again.
64,288
No flashing lights on the dash?
Is idle or run rough?
Looks like one cylinder is not firing and the unburnt is igniting in the muffler on the way out.
A
Aaron_
22
38
Florida
Thanks, I like your assessment. When running, like I said “sickly” it does sound like it’s on a single cylinder. I do have a set of plugs I keep on standby. I’ll start there.
Reactions: Jerryg
HondaTech
You have a broken injector harnesses wire most likely.
Honda issued the recall due to a misfire causing lean condition and making the muffler super hot and melting the plastic.
  • Wow
Reactions: Mudwing and Jerryg
Jerryg
Jerryg
10,954
88,230
NEPA
If that is the case, change your oil. The fuel was washing down the cylinder wall as well.
Reactions: Aaron_
A
Aaron_
22
38
Florida
One thing to note, although it was fresh gas, I’d just filled from a metal can before the issue. Maybe I dumped some trash in a clogged an injector?
A
Aaron_
22
38
Florida
Thanks! I will look into that as well. Do you happen to have a part number for that?
Edit: Disregard. I forget that I have Google and ask dumb questions sometimes. Also worth mentioning, I’ve yet to get an error code on the dash. Wouldn’t that harness throw a code?
Reactions: Jerryg
HondaTech
It should throw an injector code yes, the 16 and 17 models were bad for injector harness crimps.
There is no part number, the store on this forum sells a pigtail or you could pull the pins and crimp it again yourself.
spracht71
7
12
I have a 2016 pioneer 1000-5, doing the samething, starts in park and neutral, dies when trying to go in gear. It was under water but all oils clean, ran and worked fine for 2 days after. Got it home and problem started. Any other idea, already has a brand new battery
A
Aaron_
22
38
Florida
My advice, from the experience above, check the plugs.
HondaTech
Any water injestion that causes milky oil needs to have the rear cover removed and the transmission and oiling system cleaned thoroughly. If the unit was ran with the milky oil then the clutches will most likely need replaced as well or itll never work properly.
Ive done this procedure before and have had luck several times. I also had one unit that after thecleaning spun a rod bearing and damaged the crank from water damage. But then again, the customer wasnt straight forward the first time about the time he ran it with water in the oil.
Moat likely there is debris or trapped crus in the valve body or possibly behind the clutch pistons.
spracht71
7
12
Ran great after under water..no slips nothing at all.. next ran great,, 4 hours sittIng on trailer then didn't lol Checked oil in all, no water in it..clean all levels are at correct levels..running out of options lol
spracht71
7
12
Got new guage cluster. Now in the gear shift indicator there is a -. It blinks code 3 long 2 short, thinking thats 32. Any ideas what this could be
