P1000 Pioneer VS Defender Drag Race...
63,990
Still. That's impressive for a Honda. I bet with some hot footing and a little techenique you could close that gap.
Thanks for posting.
adnoh
adnoh
106
115
Thats a can am defender not a polaris general
66,789
I'm pretty sure the general is quite a bit faster than either of those 2 it's basically a razr 1000s
hondarock
hondarock
81
68
That is a Can Am Defender with 72 hp so they should be close, real close.
The General is in a different class and is not intended to compete with the Pioneer and Defender. Believe me when I say you don't want to pick on a General in a drag race. Just stick with the utility class.
Reactions: Plumber32
Tot
Tot
661
462
Des Arc, Arkansas
The General and Commander are what need to race because they are a cross between utility and sport.
I wonder what mode the Pioneer was in?
I'd like to see them race with 300 lbs in the back or pulling a loaded trailer.
I agree I want to see which is better pulling a load, and even pulling up hill
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
The gap stayed the same after they got going. It probably came down to driver ability.
hondabob
1,162
4,538
Prescott Valley, AZ
The lighter 3 seat model may beat it. Both will smoke the Ranger.
hondarock
hondarock
81
68
Until the Ranger 1000 gets here,,,,,, soon.
Unless Polaris decides to up the tune on the 900 to RZR specs. 75 hp should make it about even.
But I think most of the manufacturers are trying to keep the power about even with everyone else on these utility models. 70 or so horsepower is plenty for what these are used for.
66,789
the honda looked to be on gravel the defender wasnt. Honda was probably spinning at first
sthomp54
sthomp54
375
P1000-5 is 1700lbs, Defender is 1400lbs. Its over 20% heavier which makes a big diff in a drag race.
Serial_Fordicator
38
After the last can am i had, I'll either keep this pioneer or get a ranger. It was the biggest piece I've ever owned. Nothing mechanical, but electrical problems out the wazoo
