P500 Plastic Skid Plates?
papermaker
papermaker
133
586
Lewiston, Idaho
I have talked to the mechanics and personnel at my local Honda shop and they have never seen a broken or cracked skid plate. I have a 2018 500 with stock tires and have hit bottom with many rocks and such with no damage. But I did have a branch come through the floor, I took an old microwave cover and shaped it, and put it on the sides where the plate is not in hope of blocking sticks that will flip up again.
Robertb52
Robertb52
68
191
I bought a sheet of UHMW in 9.5mm thickness in black. Used the stock skid for a pattern, didn’t include any of the stock holes aside from rear diff access. Also installed stock vent under engine. UHMW is easy to work with using wood working tools, I counter sunk the stock washers and used a little longer bolts. Has withstood many impacts with rocks, stumps etc. Very robust material much much more so then the stock plastic one. Great mod.
Where did you pick up your UHMW at?
NTCPrezJB
NTCPrezJB
President of #NTC
102,361
914,911
Canton, OH
You can use single ply tp if you want but I believe most of us get better quality tp and don’t end up with crap on our hands and beat up undercarriages. Skid plates are a similar situation...thicker is better.
Robertb52
Robertb52
68
191
6921924A BCB3 4B7E A579 238D7EF8DE4A
tincangob
tincangob
200
270
Central Wisconsin
I did the research and UHMW seems to be superior for real tough riding, but it is also tough on the pocket. + or - $500.00 for a P1000. Gulp Instead I slow down and drive more conservative, but I understand the need for speed too. LOL
Reactions: Mudwing
JCart
JCart
897
2,024
Kamloops, BC Canada.
Reactions: Mudder
