Portable Winch
O
oldfortyfive
596
1,321
Illinois
I picked up one of their PCW4000 winches last January. It has been a great decision. Mostly use it for pulling logs and hung-up trees when out cutting (much safer, gets you 100 feet away from falling debris). That said I'm not a big trail runner like many of you guys, but I can see where this would be great to have around out there. While the pulling power is no what you usually have onboard your machines it overcomes a lot of problems with how to pull. You're not limited by where you can place the machine or route pulleys. It's much faster pulling and you don't have a length limitation. Their standard rope is 160 feet. About a month ago I used my P500 to anchor it off of so I could pull my old lathe bed (about 400lbs) up the basement stairs and out the back door. I used it instead of the P500's winch because I had better control due to the throttle (not just on/off). Good placement often beats out brute force with less risk of damage.
ODAMO
ODAMO
1,177
3,206
Ohio
Got any pics of dragging the lathe bed up the stairs?
What brand lathe?
O
oldfortyfive
596
1,321
Illinois
What brand lathe?
Unfortunately no. It was a South Bend 15" x 36" from the 30's. We stripped it down to the bare bed and pulled it up a 2x12 ramp.
There is a fully restored one at the Grizzley Machine store in Springfield MO.
Lathe
160,066
Depending on the weight you're trying to pull, these are pretty handy too.
O
oldfortyfive
596
1,321
Illinois
I had the 110v version and finally sold it. Hated dealing with the cable.
