P700 Prius steering
Headhunterf100
Headhunterf100
60
106
Virginia
  2. Do not currently own
Finally was able to run to my local you pull it parts yard as there website (and the guy at the counter) said they had a 09 Corolla on the yard, they did not but I did score this eps unit from an 04 Prius for less the 70 bucks out the door. Was able to modify the Prius steering shafts to mate up to the Honda steering joints and only thing I had to seriously modify on buggy was cutting out the factory eps bracket and weld up my own. Still have to paint it up and reinstall then we’ll see just have well it works out.
3621DAFA 66F5 46DF 9622 47ED530DC286 483D5E33 5894 40D1 A697 B7391F1BE712 ABA99284 F79D 42DF BA37 2F3E0545693B 377D49EA 25EA 4580 81CC 35ED377FFE14
906UP
906UP
13,017
121,358
da Yoop
Cool idea, does it have a control unit....ecm type thing or is that what the 2nd pic is showing?
Headhunterf100
Headhunterf100
60
106
Virginia
Yes the box in the second pic is a stand alone ecm for unit. For wiring it’s literally 3 wires, positive ground and a keyed hot. I have access to a lathe but it wasn’t really needed. I chopped up the steering shaft
That came with the eps from junk yard so if something goes wrong .... I can put it back to manual steering in a matter of an hour or so.
