Programable Logic Switch Box
266,444
I am sure we have some LEOs on here have any of you ever run across this switch box?
If so was it any good did it give you problems?
http://www.feniex.com/product.php?prod_id=247
I was looking at S-Pods but while cooler(touchscreen) they are way more expensive.
That Feniex 4200 is some high speed stuff, way more advanced than many LEO cruisers I have been around. I like the programmability of it but sheesh it has triple the amount of buttons most would need to bling out their SxS. The compact size though would certainly make it easier to weatherproof (to a degree) with dielectric grease. Seems pretty nice but I bet it is pricey. The typical stuff I have seen wouldn't last through a good mud ride or a spirited stream crossing without serious waterproofing.
Well a winch would take two buttons, a Heater fan would take 3, I am buying a UTV dump trailer for around our land that will take 2 for up and down on it. There is 7 of the 18 right there.
Granted I don't think I'd use them all but 7 are already gone. Its around $400, the sPod for the same number of outputs is over $1000. The sPOD source box is also about the size of a shoebox. Wiring up what I had on my 700 was about $325 when it was all said and done, and I had to do it.
I was going to mount the control panel near the roof, and seal the mainboard inside a small pelican case and silicone the hell out of the wire penetrations.
Reactions: JACKAL
266,444
That idea may very well do the trick!
