P1000m5 Project no more butt gravy
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
@Eltobgi you found one of my old threads I've been searching for some of these even with title i still cant find when i search in tapatalk or on website ! It's like after I bought lifetime membership all my old stuff disappeared cause I was on here free for about a year .@Hondasxs
Freeloader
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Added flex pipe from vent to fan back in the winter moves way more air with it on I think both ways but believe it mad it a little louder
What vent are you talking about? I'm going to cut one in for my fans
Reactions: Mudwing and BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
This one 14026215d7f4ed589ce976e4812d324f
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
It has nothing to do with you being a lifetime member. I noticed the same issue finding threads when we merged the forum to a new server/database/network or something like that.
nbomar
nbomar
4,416
17,854
Springdale, AR
Yep same for me. @Hondasxs went and found my threads.
Reactions: Lady01 and BWAF
DanDan
DanDan
193
332
Greenville, tejas
That's basically what I did. I definitely need a second fan.
I think @CumminsPusher had mounted an 8" radiator style fan at an angle under the passenger seat blowing to the back. I think I'm going to do that before summer.
Nice thing about your set up is you can reverse the wires and blow warm air in when it's cold. That's what I do
You mention CumminsPusher mounting the radiator fan under the seat. Does anyone know of someone who mounted a radiator fan on the driver/passenger side of the seat as in NOT under the seat?
BigOL3
BigOL3
2,994
8,919
..... "as in NOT under the seat?" Are you meaning to installing inside the cab, below where your knee would be, with a hole to allow it to blow back under the seat????
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I dont understand what the benefit of that would be.
Reactions: BWAF
DanDan
DanDan
193
332
Greenville, tejas
I am hoping the benefit would be not having to build some type of bracket or figure out how to attach a fan under the seat. I've seen several examples of what other owners have done within this forum under the seat. I realize by placing a 7 or 8" radiator fan on the "outside", I would need to cut an appropriate size hole. That's the reason I am wondering what the benefits are and whether I should try it or not.
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I dont see much benefit. The down side is you will have a 8 inch hole in the front of the seat that is constantly letting hot air out. You would have to run the fan nearly all the time to keep the heat away and it will be loud. If you splash through any water you will have steam rolling into the cab.
I used a flat strap of aluminum and mounted 2 bilge fans under the passenger side ofseat. It did not require any welding or special tools. I can get some pictures if you like.
DanDan
DanDan
193
332
Greenville, tejas
"You would have to run the fan nearly all the time..." OK, that is the insight that I was wanting. With the bilge fan vents, does only limited amounts of heat and steam come back into passenger compartment or do you keep the fans running all the time? Yes, post pics.
Z06
Z06
14
32
East TN
I did. Wanted to get air from outside of engine compartment with no ducting. Also very easy to mount fan this way. Works fine below 15 or 20 MPH. Above that the air flows from under seat through the fan into cab area even with fan running. Faster you go the higher the flow. Happy with the results because biggest heat issue is when going slow anyway. When I turn it on it can feel cooler air being pulled in cab.
E2D539AC E132 4A4D 9FC7 608FF6E225BC
DanDan
DanDan
193
332
Greenville, tejas
What inch fan? How loud is it when running?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
To answer your question I guess it depends where you're riding. I would think having an 8 inch hole is going to allow a lot of air or steam through. But that's not the end of the story.
So there are a lot of parts at play here. I dont currently have a vent cut in under the seat but I'm in the process of adding them. I just have 2 fans blowing back across the headers to keep the heat moving out.
Factors that affect your results.
Speed you're traveling
Front window -1/2 , 1/4 , full, vented....
Doors on or off
Rear window or mid panel
Fans on or off
Location of fans
All of these things will affect cabin pressure and therefore affect how air is moving into or out of the cabin.
BigOL3
BigOL3
2,994
8,919
Not meaning to doubt you, but I would like to understand. Seems the faster you went the more likely air would flow from cab, past fan, into engine compartment if going FORWARD. Can you explain what I am missing?
Reactions: Lady01
Z06
Z06
14
32
East TN
The area under seat must have more pressure building up causing air to flow into cab running down the road. Over 20 MPH or so the pressure under the seat over comes the fan blowing back. I would think anyone adding vent holes in bulkhead under seat would experience this. I do have full windshield, roof and hard back panel.
Reactions: Lady01 and BigOL3
