Question about diff drain plug
G
Georgiaboy
185
719
Changed all my fluids at about 200 miles, everything went fine except the rear drain plug that used to tell you it’s full, I tried torque it to 9 ft pounds and it just would’nt reach it, but it felt semi snug so no problems, we got in a deep puddle this past weekend so I decided to take a look at fluids and make sure no water got in no where, everything looked fine but that screw is not tightening up now, it’s semi snug but will not reach a firm spot, need help on fixing
64,288
Was it firm before you hit 9lbs?
Get a new bolt and install it. If that doesn't help then you need to hunt down a tap if it can even be tapped in place.
Thus why I don't use or recommend torque wrenches except for critical engine components.
I can't stress enough about NOT using one on the oil filter bolts.
Looking at it more, this bolt is in the same category.
No reason at all you need to break out a torque wrench.
Just tighten it up good and snug.
Sorry about your troubles.
G
Georgiaboy
185
719
No, didn’t loose the washer, never made it to 9 lbs, if I helicore it what size do I use and how do you keep the metal shavings out .
It never firmed up, just kept turning, i did put some Teflon on it and a second washer behind crush washer cause it felt firmer before bottoming it out, got it pretty firm like that but don’t know if it will leak
DRZRon1
DRZRon1
897
2,929
bad deal
utube, patience and grease will be your best friend
lotsa videos on repair...
G
Georgiaboy
185
719
Been scanning YouTube don’t see a lot on repairing that
  • Wow
5,098
22,926
+1.
I‘m 75 and haven‘t used a torque wrench other than critical assemblies like engines since a good ole boy told me to pay attention, you can feel when it quits turning, just a LITTLE past that. I was about 10 at the time. Use a small 1/4” ratchet for small fasteners. Torque wrenches are too long for small fasteners, you’re in trouble before you know you’re in trouble.
G
Georgiaboy
185
719
post pics of machine please
hint - search motorcycle stripped drain plug
60C7C821 DD25 4B3A BFE4 A179AED2D0E9 3A5F7451 B381 4992 B2D0 E3DB69E1B69C
G
Georgiaboy
185
719
I was told to tap it out to a m10- it’s a m8 now, I ordered a m10x1.25 plug with copper washer and magnet , anyone else do this before I try it
5,098
22,926
I'd be ok with that. For the SAE guys that's 5/16" to 3/8". The other option is a helicoil or time-sert and I think going oversize is less complicated and quicker.
G
Georgiaboy
185
719
I think so too , ordered 2 bottles of diff fluid so I could flush it out a little, my only worry is shavings getting in there, but with them being aluminum I can’t see it hurting much
5,098
22,926
Yeah, I have a hard time getting anal about a few aluminum chips floating around steel gears myself. Not the best, but no need for panic either.
