P500 Question on 50" and Tires
155,558
1" spacers add enough stability? Honestly, is the stability stock that bad? I just want to cruise around on the 50" trails here. I had a p1000-4 in white a few years ago when i lived in CO. I loved that thing but i moved for work and couldnt take it with me. Now i am itching to do something again but i no longer have the big truck, toy hauler and all that to mess around with a big pioneer so the p520 seemed perfect. I do like to hill climb a bit, nothing major just some light fun. If i cant get through the gates it would be for nothing. If most gates are a bit wider than 50" that would be awesome.
Yeah 1" is enough. If you're on stock tire size you can leave it alone but if you go up you should go out.
Mudder
Mudder
NTC Ambassador of Walls
11,303
83,907
And actually makes it worse. 26" BH's on stock wheels and no spacers was a pucker fest! 1" spacers will put you at about 52 1/4" IIRC and that was doable. 5+2's will put you at about 54 +/- . Like Futz said, chances are good you'll get through the gates anyway.
Similar here, 5/2 rims with larger tires ended up 54” wide. Still fit thru local USFS gates and USFS Ranger said ok. Ranger was more concerned about riders who do not tread-lightly on trails.
jelmail2000
jelmail2000
30
41
US
I am getting the feeling as long as i dont go too crazy on width i can fit through most gates. Great info thank you.
MI-Trailblazer
MI-Trailblazer
258
1,208
Parma, MI
My experience with my P500 is one of not the "norm" I'm gathering from years on this site. I come from many years of riding 3-wheelers and sport quads. Therefore, I do not know what a "smooth" or "cushy" ride is. This is the first machine that I've owned with 4-wheel independent suspension, even though I'm told it is bad. OK, yes the P5's suspension has it's limitations because you can only put so much suspension in the space available. As for the tippy-ness and unstable: I only felt my machine had an issue when I was crusing in 5th gear at about 32 MPH and tried not to lift on some tight corners.
Biggest thing I can say is get some bigger tires that are radials- I have 26" Kenda Bear Klaw HTR's on my stock wheels and when I put those on the ride and handling improved 2 to 3- fold over the stock tires! I ran this set-up for close to 2 years on the 50" ORV trails here in Michigan and never felt like it was unstable.
Next, get rid of the rear sway bar. The bar is way too stiff for the machine and I found that every small bump/rut/rock/hole you hit with the rear, the sway bar transferred that hit right to the frame and right to your rear-end in the seat. I finally removed mine after 2 days of riding in Moab and figured out the swaybar was transferring the hard hits.
Between the radial tires and sway bar removal, I think my machine is way more stable and rides better than stock!
Now a few on here may remember that I did put 1.5" spacers on all 4 corners before my Moab trip (2021) but I've been too lazy to take them back out. I believe that I could remove them and be just fine. But these are not a high-speed handling machines, so my putting around on trails up north around 10 ~ 25 MPH it does just fine.
