P500 Radiator overheating sprayer?
Mudder
Mudder
NTC Ambassador of Walls
11,382
84,889
Could have used this at Takeover for overheating. LOL. On sale today.
9B250FA1 D48C 4442 B823 7FEBE8B16F8A
Tramguage1
Tramguage1
Texan
7,182
27,653
Somereset, Texas
We stopped a couple times to use the creeks for washouts. I WILL have a system next year.
Mudder
Mudder
11,382
84,889
We had several machines that way. Thanks to @trigger for the water. Pin hole in plastic water bottle worked in a pinch. Ordered the pump for a try out, will post a review.
Bastardchild
Bastardchild
1,978
7,250
Orange Heights, fl
It would be neat to have a water reservoir somewhere on the sxs and a 12v pump plumbed to it. Then have a pvc or metal pipe mounted horizontally in front of the radiator at the top with holes drilled in the pipe from one end to the other. Flip a switch on the dash and the pump sucks water out of the reservoir and sends it to the pipe over the radiator and it shoots out of all the holes you drilled in the pipe and sprays on the radiator fins, cooling it down. One draw back to this is you wouldnt be able to help someone else that needs theirs sprayed, or you wouldnt be able to wash other things off on the trail. You could probably get creative and have a valve that you can turn to keep the water from going to the radiator and divert it to a spiggot where you could have a quick connect hose fitting and hook a hose up and spray someone elses radiator or your windshield or something. I was thinking of this at the Takeover when @knuckledeep had to use his livewell/bilge pump set up to cool mine down a few times.
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
can't go wrong with a bilge pump and a few gallons of water
Reactions: Bastardchild
tr005
tr005
491
2,660
Big Rapids, Mi.
26216E1D EB37 42DB B81E 3A07C742D1F4
I carry one of these. A little pricey new but works great. Got mine from my dad. He had it since I was a kid.
O
oldfortyfive
596
1,321
Illinois
View attachment 76638 I carry one of these. A little pricey new but works great. Got mine from my dad. He had it since I was a kid.
You can find them at yard sales for $10. I prefer the old ring neck type. I put a air valve in the lid and replace the fire hose with a hose and spray nozzle. The big neck is easier to fill and clean. I use them for all kinds of things.
