Radio Static
MalibuKid
WI
Hello all-
I have a radio setup on my Pioneer 1000-5, when bought the machine used the previous owner already had this installed. There was no antenna hooked up when I bought the machine so I purchased an antenna that is wired to the radio and is hooked up the battery to amplify the antenna. Many people use these on motorcycles from what I am told. I mounted the antenna to under my plastic hard top roof. When the machine is off I get a ton of channels and great sound quality, but I turn the machine on I get tons of static and lose many of my channel options. Any suggestions???
I have attached a picture of the radio that is installed on my machine.
Thanks
JBL UTV Radio
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Make sure the antenna is completely away from any electrical wires
Reactions: Remington
109,663
Add a Ground loop Isolator.
What ^^^^ said and just a real ground for that stereo. I have one similar and you need to do a good ground or she’ll make noise.
