Rallycross/shortcourse tires
Brazula4life
74
Florida
Has anyone ever tried car rally tires for racing? Alot of people like hoosiers but good luck finding them. I heard rally tires works just as well.
Reactions: Smitty335 and ChadD
Brazula4life
74
Florida
If it was up to you what would you run? I know you have lots of experience already racing your honda. I might run all 4 corners with front talon rims.
Also another thing I forgot to mention, is that the maxxis rally tires are only $130
SLOWPOKE693
SLOWPOKE693
1,612
6,118
Somewhere in Texas
There is no correct answer. If you think the Maxxis tires will work, buy those. If they feel good keep running them. I've only ran Hoosiers and American Racer dirt track tires so I'm not versed in the rally/winter tires. I'm just basing my answer on what I see other people running on their cars at different tracks.
I'm not a fan of skinny wheels and would run at least a 7" wide wheel. I've had good luck running 4 rears.
Brazula4life
74
Florida
I wouldn't mind at all running 4 rears, more contact is always better. Do you run spacers in the back or just keep the rear slight wider?
SLOWPOKE693
SLOWPOKE693
1,612
6,118
Somewhere in Texas
Front ends up being wider with 4 of the same offset wheels. I don't run rear spacers on my car ever. Being narrower in back helps with turn in. Everyone does that rear spacer crap for "looks". 🙄
Reactions: Brazula4life
Brazula4life
74
Florida
I dont care how it looks, I just want it to handle and work better. I'm sure that improves traction, front tires are very narrow
PaulF
PaulF
1,462
4,810
That is completely untrue. If you were a rock crawler or off camber rider, you would know why some folks benefit by running rear spacers. Just because something doesn't apply to you racers doesn't mean it isn't valuable to others.
For you intended purpose, do not run spacers. A wider front will cause a slight oversteer and handle much better on the track.
Brazula4life
74
Florida
Came across someone getting rid of brand new set of 15s wheels and tires from their talon r. My tires have seen better day, I will try running all 4 rears as you mentioned. I assume I should run the new set on the front and my used ones on the rear. Am I correct ? Also what tire pressure do you recommend?
SLOWPOKE693
SLOWPOKE693
1,612
6,118
Somewhere in Texas
I've never ran the stock tires, only stock rear wheels with hoosiers on them and I stopped using the wheels because I was peeling rear beads at the pressures i wanted to run the Hoosiers at.
Beadlocks or Method Bead Grip wheels would be the way to go if you plan to slide it around with low air pressure.
