Rancher AT lost in gear
Pioneerpilot
Pioneerpilot
9
Mississippi
I have a 2014 Honda rancher 420 AT with the DCT and it’s been lost in gear for a couple months now. It just shows a dashed line on the display and it won’t ever pick up that it’s in neutral. We replaced the angle sensor and not sure where to go from here
  • Wow
Reactions: ChadD and Smitty335
56,680
Battery good? My '18 Rubicon will do that if I forget to put it on the battery tender and the voltage drops too low.
HondaTech
The early AT models were bad about breaking the spindle return spring pin.
This is easy to diagnose, if you try and manually shift the unit the spindle wont return to center on its own. It'll feel mushy and wont easily shift between gears.
Is it currently flashing any codes?
Reactions: TripleB and Adam490
