Rear prop shaft rotational play
lukpy8810
lukpy8810
91
203
Minnesota
Should there be any rotational play in the rear prop shaft (between trans and diff)? I can rotate mine about 1 half turn by hand before I see any engagement of the rear differential (machine is jack up in back and in neutral and turf mode)
108,167
Id say thats a bit much!
Did u fix the other related problem you have another thread on?
Reactions: TxDoc
lukpy8810
lukpy8810
91
203
Minnesota
No I have not yet! I just figured I should ask this question in a separate thread since the other one was quite lengthy.
It's going to the dealer today after I get home from work. I suspect the diff will need replacement or rebuild. Could do it my self just don't have the time
Reactions: Remington and CID
108,167
Right on.
make surebu get an estimate first.
And please come back (to the original thread) with results. Too many start a thread and never come back and leave us hanging like Epstine
lukpy8810
lukpy8810
91
203
Minnesota
Right on.
Lol will do I'll.post on the other one when I learn more!
