P1000m5 Replacement body cost & part numbers
  • Thread starter Justin_Pack_SouthernHonda
  • Start date
dezs1775
dezs1775
67
133
Orange city Florida
do you have a better pic of the metalic silver up close
IMG 4086
45
Chattanooga Tn.
www.southernhonda.com
UPDATE***** The small rear pannel apparently is the wrong color code. 81555-HL4-A10ZB (white) should be 81555-HL4-A10ZD. WHEN ORDERING A CERTAIN COLOR, MAKE SURE THE COLOR CODE IS CORRECT FOR EACH ITEM!
THE SILVER COLOR CODE IS *NHB68MR*
THE WHITE COLOR CODE IS *NH196*
THE CAMO COLOR CODE IS *YRA05L*
THE ORANGE COLOR CODE IS *YR222R*
Scooterchris
No longer active.
Dec 25, 2015
396
237
Hey justin can you see if you can pull a string and get me the white front fender And the driver side front door in white ofcourse. The company I ordered it from is still saying backordered. Let me know
Bonehead69
Bonehead69
73
44
anyone know what the body bolts part numbers are? I have one that is stripped from the factor of course.
45
Chattanooga Tn.
This is what is showing on the diagram.. It doesnt show a cost but if you call a parts center and give them the number they should be able to pull it up. I attached a diagram so you can see if there is anything else you may need. I hope this helps!!!
026 SCREW, SPECIAL (6X16) 90114-MFL-000
  • honda diagram.pdf
45
Chattanooga Tn.
Hey Justin can you see if you can pull a string and get me the white front fender And the driver side front door in white ofcourse. The company I ordered it from is still saying backordered. Let me know
Sorry ScooterChris, I have been extremely busy and haven't had opportunity to get on as much as I like (we are very short staffed!) I assume you have got everything resolved but if not give us a call and we can order it for you (some panels we have a couple in stock). 800-959-5432. Happy riding!
Bonehead69
Bonehead69
73
44
Thank you very much that helps alot!!!!
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
I've been watching this thread and thinking how much I would like to have new plastics for my 07 Foreman. Holy Cow. Why are they so much more expensive?
Bowtech32
36
20
Can the deluxe rear panels be installed on a non-deluxe model???
5417arms
14
12
VA
View attachment 9609 View attachment 9610 View attachment 9611 This is what it looks like with the panel off. We have had a couple customers who want the upgraded tires/wheels, and LED lights, but not crazy about the panels. I had one guy who was going to take black washers and put over the inserts(may need shorter bolts also). He also mentioned painting the "nut" black so it blends in better. He plans to keep the panels in good shape and slap them back on when he goes to sell it. It will be scratch free and look almost brand new(on the sides lol).
Do you have the part numbers for the clips and screws that hold the body panels on?
5
5417arms
14
12
VA
I've looked at the parts schematics before, but they don't show the part that the screw attaches to. I have a non-deluxe P1000 that I bough body panels for, but the doors did not have any attachment provision for the panels. I have since used some windshield screws, but I have had a few pop out and wanted to find the parts used from the factory.
13,468
66,403
To replicate the factory installation, you would need the special screws with a shoulder and some sort of nutsert to insert into the door.
Have you considered using the plastic rivets/push pins to attach the panels?
Reactions: bobbyhill
5
5417arms
14
12
VA
I had not considered the push pins, but that would probably work great. Thanks for the suggestion.
Souldaddy
Silver city NM
Hey Justin,thanks a lot for all your help with part #s for replacing panels.you are the man! I have a 2016 1000-5 deluxe that is white and am wanting to see about replacing all the white panels,hood and front fender section to the limited edition matte grey metallic.any help with part #s and prices would be awesome. Thank you
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
@Souldaddy plan on selling your white panels?
