Ride report for the day.
Killer223
Killer223
266
535
drove a good long while today almost 80 miles. major complaint thus far, the throttle sensitivity needs to be cut in half when in low range. lots of the roads i go i average 10-15 mph. over rocks, and each rock pushes machine and the go peddle, so it's not easy to make a smooth ride out of it. i struggled with this most of the day. even bracing my leg and knee against the center frame work didn't make it a whole lot better. The can-am has an ECO mode, the honda needs something similar.
ground clearance is awesome, so much better than the commander. And i really like the seats.
slow rock crawling is easy no worry of burning a belt, clutch actuation is nice and smooth and predictable. i liked it. just don't come off a rock and goose the gas, then the machine lurches forward!.
All in all was a great time today, ended up headed out to a desert spot and found a small water berm and jumped a few times. only a few feet,
speed limited to 74, when you hit 75 it fuel cuts to slow you, so you bounce between 74-75.
next trip out will be with out a rear sway bar. see how it does in the rocks then.
41,839
74-75?
I'm assuming you have a Talon?
Reactions: sharp
41,839
This post being in the talon sub forum is what tipped me off..
LOL...opps. I always use the recent posts link and look for the banners.
That's one Talon in AZ for sure. Keep waiting to see the 1st out on the trail.
Reactions: nbomar
