Rocker switch
Ryanp502
Ryanp502
34
122
New Haven Ky
I’m in need of little help!! I put up a 12’’ nilight for a back up light. The problem I’m having is it’s wired up good. But when I hook it to the rocker switch it will come on. Then once I turn it off it won’t work anymore. I got one ground from the light hooked to the ground on the switch. The other ground has the ground from the fuse box. Then I have a hot wire coming from the fuse box and the hot wire from the light going to the correct spot to where it says to hook them up. I’m using method A. Any and all help is greatly appreciated
Image 8C854C10 EBC9 43F4 977F F44AE1312F18 ADE1A214 68F5 490D 9D2C 45B7CE4C5009 FFD86E24 6264 4C60 8F3E DCED22318F47
Squeegee
Squeegee
JTGB in training
29,869
266,409
View attachment 338901 View attachment 338903 View attachment 338904 View attachment 338905
Sounds like you’re trying to ground the light through the switch. Run light ground to fuse panel then run a separate ground to switch. The ground on the switch is just to ground for the switch illumination
Ryanp502
Ryanp502
34
122
New Haven Ky
Ok thanks that makes sense. I’ll try that thanks for your assistance
Ryanp502
Ryanp502
34
122
New Haven Ky
No problem hope it helps
I hooked it up like that it come on and off now. But when it’s in the off position it flashes off and on. I believe it’s a bad rocker switch
Reactions: CMB
Ryanp502
Ryanp502
34
122
New Haven Ky
I got it all hooked up right. The rocker was flashing in the off position. Finely my dumb ass figured out the power wire connector was touching the light connector and making it flash. So I heat shrieked them now we good to go. Thanks for the assistance
D5B4C56B A49A 4738 9730 7B22E0C9478E
