P700 Roof insulation
kevinpo
kevinpo
38
173
Spokane Valley WA
I searched but I couldn't find any threads about roof insulation. I was thinking about installing Noico 80mil sound deadening insulation in the roof of my 700-4. Has anyone done this? I was hoping to reduce some of the cab noise. A decibel meter is about $20 on Amazon and I would do a before and after reading if it hasn't already been done.
Regards,
Kevin
109,467
No not really. One reason if it gets wet your screwed, and Its not gonna help with noise unless you have a full hard or soft (NoHomo) cab. I tried in other areas of my p1 different types of insulation and was a big waist of time Unfortunately the best way to lighten the noise is to remove the hard top. Depending on when and where u ride thats not the best idea. Or ware some ear plugs or some Walkers game ears.
Ridinfool
Ridinfool
36,145
386,041
Western North Carolina
This'll help.
I’ve got this on my P1K and it works great, is it going to stop all the noise? NO!!! But it helps quit a bit, remember, you’re setting on the motor.
I also agree with @Remington as far as insulation getting wet and making a mess. If your looking for quite you might look into a jeep…
Vikes79
Vikes79
SKOL!
11,190
108,728
South Dakota
  2. Talon X4 LV
1676682443059
GovtMule
GovtMule
NTC’s SoA, Chief Sarcasm Officer-Self Appointed
13,095
127,514
Tennessee
Regards,
Kevin
Looking at the pic…is it red? If so that’s the problem. Green ones are noticeably more quiet so you might not need the insulation. They have more power as well, due to the enhanced flux capacitor.
42,203
Regards,
Kevin
I experimented with this notion back in 2014 or so, but never implemented it fully. I had a large bungee net on the underside of the roof, and we would store coats and blankets...anything soft and light in it. Did kill sound enough that I think it's worthwhile to try. I'd do some of that acoustic foam like they line sound studios with.
As @Remington said, it will eventually need to be replaced due to the elements. I wonder if you could maybe glue Velcro sections to the roof and panels and make it easy to remove?
And as mentioned, @trigger has a solution to stopping the sound long before it reaches the roof, if you don't feel like "rolling your own".
