P1000 Rough Country Shocks
107,604
Thats a hard Nope!
How bout Pics and a Link?
Reactions: Smittyp
Bighat
Bighat
875
3,740
Gallipolis Ohio
I don't need shocks but I had to check it out. I didn't the made them for UTV's but they do.
1662245618319
M1 Front Coilover Shocks | Pair | Honda Pioneer 1000/1000-5 (16-21) $349.95
107,604
Robobrainiac
Robobrainiac
2,470
8,627
Those are cool! They have front or rear for $350 a pair. Are adjustable and look like you could potentially swap springs for different rates.
Reactions: Smittyp
ChrisCrockett
22
138
West Texas
My challenge is I am running bfg km3 tires at 10lbs and they are stiff causing a ruff ride. My riding is on gravel/ rocks on the ranch. I know the 814’s will be a smoother ride being able to adjust compression and rebound.
ChrisCrockett
22
138
West Texas
I got them mounted in about 2 hours by myself. I didn’t adjust the springs before putting them on. It has raised my p1k about 2” inches. Brief ride and it rides smooth. I will know more in a couple of weeks when I get back to the ranch. My factory rear shocks were adjustable I found out after taking them off. I am going to lower it by an inch all the way around. Pic is sxs comparison.
ChrisCrockett
22
138
West Texas
11E6E9F7 9F47 484C A351 BE23026BBA62
ehart814
ehart814
1,654
3,643
NWPA
My machine bottoms out so easily on the front end. I have the JEI front bumper, Warn 55 Axon winch, Dual battery setup, etc so a lot of extra weight up front. Even if these just have a bit stiffer spring and some actual damping, they would be well worth the money. I'm not a high speed rider, I just don't want to bottom out on every little bump
TripleB
TripleB
11,937
101,376
Caryville, Tennessee
That's definitely the worse part about the stock shocks.
