P1000 Rough running
DavidGK
5
17
2019 Pioneer 1000-5 running rough. Spitting a lot of gas out of exhaust. Changed plugs with no difference. Checked new plugs. Front one is burning good but back one looked like new after running for a few minutes. Changed rear coil pack. No change. Thanks in advance for any help.
JenElio
JenElio
65,108
609,317
Loxahatchee, florida
Welcome to the forum. If you're sticking around start a intro thread, lots of good info ideas around here.
So, you gotta give us a bit of history on the buggy. Miles, usage, did it just start out of nowhere or did something happen and then caused this issue?
DavidGK
5
17
Sorry about that. 439 miles. All trail riding. Sat for a few weeks after running fine. Started it up and problem appeared.
JenElio
JenElio
65,108
609,317
I'd start by checking the injectors/harness wires. They sometimes act up even though they may seem ok from outside. Check out the club store for the upgraded wires...... that'd be my first (✔️ to do)
107,340
Welcome fellow Michigander and fellow Big Gretch sufferer.
Need Pics of your rig. Kinda a thing here when u join. POIDH. And all the things @JenElio AKA jennay said!😉
You trail ride in Our state, and that means 2 things, water in areas and Sand dust. If you were in water good, you may have water in your intake. If you ride on our dusty trails and thats hard not to do here, check that air filter. If you dont have a pre filter snorkel, that baby will plug up super quick and make the motor run like a 68’ Volkswagen
Swampmonkey
Swampmonkey
146
141
Al
My 2019 is doing similar thing. Sputters intermittently during low speeds, runs fine at higher speeds. Changed air filter, IACV, spark plugs and fuel pump. Im gonna drain fuel out this weekend and put new fuel in. Fuel injector wires arent loose and not having a code. Last resort is fuel injection wire kit which I have already purchased.
107,340
Thanks for help. I will be going back up north to try swapping out the injector wiring harness.
Dont forget to get some pics while your there and post em up! We’ll be anxiously waiting😉
BTW where is north for you?
Mine is near Gaylord
Reactions: ChadD and Plumber32
107,340
Our up north is Prudenville, just south of Houghton Lake.
Nice! Thats just tutor hair for me from home roughly 2hrs. I prefer at least 3hrs to be officially North or I might as well live there lol. But if u ask a Yooper we aint up north at all🤣
Swampmonkey
Swampmonkey
146
141
Al
Did the fuel injector wire kit this week on both. No change and seems to be getting worse. Im stumped.
Reactions: ChadD
Jerryg
Jerryg
10,784
87,039
NEPA
Did you drain the gas tank completely and refill fresh?
Reactions: ChadD
