Russ989
I will try to do that tomorrow.Hey Russ you ever get a chance to measure your width in the front?
Lol that’s awesome!! I’ve had two rangers and both were ok but I don’t work mine that hard! The 1990 Honda Rancher four wheeler I bought in 90’ is still a work horse although it is a bit ugly now! Like me! I currently have a 2020 Honda 1000-5 limited! Great machine! One problem was a CV joint was bad after 200 miles so dealer replaced no issues! Thanks guys I enjoy the reading! I’m in Willis Texas!I like your thinking JB. I might have to incorporate those ideas!
Where can I get these lights with plug n play harness?I also added the 12” add a light bar kit from the store as well. It works on your dimmer switch when you turn on your high beams.
Here is the link to the light form the HondaSxS Store.Where can I get these lights with plug n play harness?
Nice setup, I’d like to check out those harnesses at the TO.Finally got around to installing the harness bar from Brick City Fab and the Dragonfire Evo harnesses.
View attachment 274442 View attachment 274443
AbsolutelyNice setup, I’d like to check out those harnesses at the TO.
Bout time. Looks goodFinally got around to installing the harness bar from Brick City Fab and the Dragonfire Evo harnesses.
You're going to like the Evos. Great harness for trail riding. Just dont ride in a machine with Can-am 4 point retractable harnessesFinally got around to installing the harness bar from Brick City Fab and the Dragonfire Evo harnesses.
Wheel spacers?Russ looks like you are still running factory axles. Is this why you only used 3/4 inch spacers? I keep a dial caliper in my office and ordered some 30 dollar spacers from PBR and the fronts are 1.125 in and rear spacers are 1.375 in. I was thinking of stopping over at a buddys house and parting them to .875 ( 7/8 ths) and calling it good . Curious about this .
Ohhh..... Most 30s will rub unless you get off set a-arms.Shock spacers for lift so 30s do not scrub
You will need offset A arms to clear 30s and some 30s will need A arms and a lift to clear depends on how true to size they areShock spacers for lift so 30s do not scrub
They are pretty good for what they are for sure. Mine have had a lot of brush drag across them and are still in great shape.Nice job on videos I would never attempt one on doors more than you think but not a bad job , I'm 2 years in on upper doors still no problems
