School me on RAM 5.7L HEMI Exhaust Manifold Kits
Mopower58
Mopower58
CST is the Best!
70,927
650,023
Crystal Springs,Ms.
Did you see this? I have no idea about it’s durability.
63,987
It's too cheap to not be China-made as well.
Mopower58
Mopower58
CST is the Best!
70,927
650,023
Crystal Springs,Ms.
When mine gets worse, I’ll probably just do the BBK’s. They have a thicker flange that bolts to the head, don’t have to change any other exhaust, and just tie up heater hoses away from heat.
Mopower58
Mopower58
CST is the Best!
70,927
650,023
Crystal Springs,Ms.
63,987
@Hondasxs did you see these? Redesigned and have a warranty.
Oh. I like that.
Redesign to remove those double bolts is good.
Mopower58
Mopower58
CST is the Best!
70,927
650,023
Crystal Springs,Ms.
I see. On the Ford modular motors in the day it was corrosion related…at least up north. You could look at the stud the wrong way and it would fall off.
When I was at the ford dealer we had trouble with 351’s and 460’s warping manifolds. When the manifold warps enough it pops the bolt.
63,987
john790
329
1,012
Clinton ohio 44216
How about a good bolt with threaded bolt hole in them you can always make your own studs.Dont do the belt sander if at all possible they lie by looks.A mill wont lie.And dont cut a real warped manifold because your holes will be off and the worst part the bolt end will be crooked to the flat surface.
Reactions: HBarlow
HBarlow
HBarlow
1,614
5,997
Daniels, WV
I agree with that advice above. @Hondasxs I didn't want to belabor the point if your mind was made up about using a belt sander but I believe it would be a mistake. It would be difficult to hold the manifold exactly parallel to the manifold surface. You could end up removing metal from the wrong area(s).
I would have the surface milled by a machine shop or engine builder. It shouldn't cost much and will give you a true mating surface. If the manifold is warped enough to infringe on the end bolt holes you'll be better off to replace it.
63,987
I ordered the header from the link 3 post above. I think that is the solution I was hunting.
With that... I can get some ARP bolts.
Reactions: NewHere2
HBarlow
HBarlow
1,614
5,997
Daniels, WV
I ordered this today.
I don't have any personal experience with Thorobred Diesel but I know they've been around for many years.
That looks like a wise choice. New manifold(s), gaskets, and fasteners and a warranty.
Reactions: Mopower58
Vikes79
Vikes79
SKOL!
10,971
106,495
South Dakota
  2. Talon X4 LV
Personally I believe that bossmans truck would be so much better sounding and looking with these. Preferably up through the hood imo.😈
1703172307466
Lower the front end, add some nitro and release the vrooom!
63,987
WOW..... Tracking says it's already at my door.
Hell ya.
Mopower58
Mopower58
CST is the Best!
70,927
650,023
Crystal Springs,Ms.
Hell ya.
Are you going to install these or get someone else to do it? It looks like the bolts are extra long and have spacers that slide onto the bolt to help with thermal expansion.
Reactions: NewHere2
