P700m2 Seems rough
L
LB5419
6
Copenhagen, NY
My pioneer 700 seems to vibrate quite a bit a low speed and when taking off. Had a Big Red and did the same thing. I assume this is normal for this engine and machine?
swsebek
swsebek
2,854
5,829
pa
You will get used to it....Toque comvertor
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Just let it warm up a bit before taking off... Mine seems fine and smooth. If it really bothers you and you think something is wrong , take it back to the dealer, if you trust them and let them take a look at it.. I'm switching to Honda Pro Full Synthetic 10W30 at next oil change. Since the engine transmission and torque converter all use engine oil, I'm thinking the synthetic will work better for the torque converter in the winter months as it will not thicken up like conventional oil..
Reactions: Mudwing
Tramguage1
Tramguage1
Texan
7,143
27,177
Somereset, Texas
I also noticed this with mine. I think it being single cylinder also has this trate
allgm1
allgm1
1,049
1,484
New Hampshire
I saw a video a guy did of the engine while he rode it, you wouldn't believe how much the engine thrashes around.
Reactions: Tramguage1
Mudwing
Mudwing
36,959
306,563
The Mud holes
I drive mine just about everyday. At first it maybe seemed rough but now that I'm used to it, it actually seems quiet.
Reactions: swsebek
BAMASXSRIDER
36
64
ALABAMA
I had the same thought when I first got my 700-4. It still vibrates a lot taking off, but after I adjusted the front and back doors, added some foam tape in some areas where the seats fold down on the bed and around the tailgate, the rattles are gone and it doesn't bother me near as bad.
Reactions: Mudwing and swsebek
MattSadler
MattSadler
88
175
Kentucky
I put the fuzzy side of some velco wrap around all my door latches ( part that latches clasp onto )and bed latch and it dont rattle at all. It has to be replaced about every 400 miles or as u start hearing a rattle.
Max718
Max718
246
366
Mississippi
I put a couple wraps of black tape on my door latches no rattles now
Similar threads
