P1000 Self-Levelling suspension
JenElio
JenElio
64,081
601,480
Loxahatchee, florida
the wheel runs true on the machine no wobble at all... and it's already been into the dealer for this under warranty. I was told the tire pressure was too low and sent on my way.
I measures the distance between the center of the bolt on the frame out to the center of the bolts at the wheel hub everything matches compared to the opposite side within <1/16"
Originally I was concerned that maybe one shock wasn't developing pressure as it should under load, which is why I was asking the question. After further inspection the shocks are fine.
The only remaining thoughts I have are that the ears could be welded onto the frame in the wrong location or that the wheel hub casting is off somehow? I will tear into it more tomorrow
Interesting, just for the sake of asking......what kind of surface do you ride mainly?....are you riding in Turf or 2WD? And are you by any chance making more right turns the left (serious question 😂).......I recall at cpl people having more wear on one side then other from too many turns one way vs the other (on a locked rear end though)
105,179
20psi on ATV tires
the max inflation pressure is listed at 35PSI which I realize is for seating the bead.
I had the tires at 10 and when it went into the dealer for this issue told me it was waaay too low and inflated the tires to 16.
20 is way too high unless your running an LT tire on pavement all the time. Your dealer dosnt know what they are talking about telling you 10 is too low and go to 16! Just sayin
Dan-Squatch
15
73
Thunder Bay, Ontario, Canada
Why do you think I brought it home to tear it down ;)
and yes they were a Goodyear Duratrack on a 15" rim under a can-am 850... worked perfect for plowing the snow
5,022
22,428
16PSI in the tires, well within the acceptable range.
I just finished taking the toe measurements... its bad
on jacks 1-1/8" toe in
on the ground 13/16" toe in
With these numbers and still under warranty, I'd tell the dealer to fix the damn thing and call me when they get it right.
105,179
Shut the front door!
The discussion is about your Honda and the UTV tires on it. They sure as $hit dont look like GY Duratracks. Nothing was ever mentioned about a Canned Ham Commander? Is their something were missing?
Reactions: TxDoc
Dan-Squatch
15
73
Sorry for being unclear, the Tires I was running 20PSI in were GY Duratracks under an outlander 850
105,179
Ah ok. Ive been known for missing something in a convo, usually with my wife cuz it sounds like the peanuts teach mumbling 1/2 the time😂 but this one threw me off
