P500 Shadesmn p500
rocmar
rocmar
4,741
5,775
4 CORNERS
Reactions: ehart814
rocmar
rocmar
4,741
5,775
4 CORNERS
Thank you. It's made a pretty good transformation from when it cam home. Always more to tinker with though.. :)
Agree
....one thing leads to
another. .....
O
oldfortyfive
596
1,321
Illinois
Yet another interesting way to create storage under the drivers seat. :)
Reactions: Shadesmn
Shadesmn
Shadesmn
505
959
Ramsey, MN
Its not water tight, but a couple holes for drainage in the bottom and a small plastic bin to keep stuff dry works just fine. :) it was quite the process to build in there, but it fills almost the entire cavity for almost no cost compared to alternatives
Reactions: JTW
rocmar
rocmar
4,741
5,775
4 CORNERS
I like it.....
Shadesmn
Shadesmn
505
959
Ramsey, MN
Its pretty low tech. Some 1/2" plywood combined with some sheet metal bent to shape and screwed together. Then i sprayed the outside with that flex seal type spray. I also had to add a small access panel to the inside wall to get to the oil access.
20151002 215312
Longbrake500
Longbrake500
96
168
Anna Ohio
nice setup.. I have my 66" eagle plow on order been a couple weeks now. I ordered it with the hydro angle kit so we will see how that works.
Shadesmn
Shadesmn
505
959
Ramsey, MN
I haven't seen or used the hydro setup, but i can say the blades and push tubes are tough as nails. My dad has used his for 12 yrs on gravel driveway and roads without any issues aside from normal wear on the wear bar.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Forgot to add that those Reptile tires have been working well for me.
good to hear. I haven't seen too many others on here running them, but my tire guy assured me they were what I should go with and he's never steered me wrong so.. I love them, waaaayy better than stock for sure.
Reactions: rocmar
Shadesmn
Shadesmn
505
959
Ramsey, MN
And snorkel pics too..may add another 22.5° fitting to bring more flush with roll cage. Gets close to stuff on the rack sometimes..
20161013 151318 20161014 233600
Rokrangr
Rokrangr
6
Fleetwood, NC
That's a nice rig. What headlight conversion did you use?
Sent from my SM-T113 using Tapatalk
