Hey all.
I’ve been working on reorganizing my shop to allow for better utilization and to make room for my side hustle.
I’ve completely relocated my 60 gallon air compressor and am trying to decide what I should plumb the shop with. With what I’ll be doing i will need very clean dry air for for atleast 1/2 of the network (hvlp plasma etc), the other side won’t matter so much (tires, air guns etc).
I already have my submicron filtration, dessicant, and compressor radiator on order…but what I’m on the fence on what to use for the network itself. I’m planning on at least 3/4” on the main line which will have a max length of about 50’ and each drop will have a port and drain valve…maybe regulator.
I don’t want to use black pipe due to contamination.
I love working with copper but it sure is expensive and time consuming.
I believe that Pex A could work as it’s in an enclosed shop…but I’ve never used it and don’t have any tools
I hear about this type system a lot but don’t know much about them overall. Not sure it’s a good fit as none of the fittings are available to me without driving a couple hours…
Maxline Pressured Leak-Proof Easy to Install Air Compressor Accessories Kit Piping System | 3/4 inch x 100 feet HDPE-Aluminum | Connects w/ any Air Compressor Hose | 100 PSI | 29 Pieces | M7500.
https://www.amazon.com/dp/B005FKYRTU?tag=sxsweb24-20
I’m curious to what everyone is running and why? I think pex A could be cheaper….just not sure about the durability..
No…I’m not going to use PVC…
