P1000 Side mirror options
dweber23tr
148
473
Minnesota
I tried to search but couldn't find the answer, are there any options for side mirrors that will work with the factory full hard doors? With the full cab visibility behind the pillar/panels is very poor and mirrors would help, but all I can find that seems that would work are the factory honda mirrors, which also come with the honda price tag, so wanted to see if there were any other options.
Reactions: TxDoc
NorthernJoe
NorthernJoe
325
1,250
Northern Ontario
There are two bolts below and behind the door handle, make a bracket to bolt to the door using those two bolts and mount any mirror on the bracket that you want
Dirtstiffs-1000
Dirtstiffs-1000
1,560
5,682
hondasxs.com
20240316 173522
Not for hard doors but worth mentioning for Oem mirrors and Soft Upper doors.
These are the best bracket mounts made to mount both Honda OEM Mirrors, and Honda Soft Upper Door panels.
Made from high quality HPE material, with precise symmetrical engineering and design.
Modeled and fitted from an actual Honda Pioneer.
3D printed bracket, designed and proven to be super strong, light weight and easy to install.
They include easy to follow installations.
These work perfectly and solve the endless search for mirrors that function with Honda Soft upper doors.
These brackets can also work with about any manufacturers bolt on mirror mount pattern.
Contact @tjoreo for bracket information.
Great guy and forum member. 👍 👍
20240204 154404
Reactions: NorthernJoe
