P500 SIDE PIECE p500 /P5RSMPU
Mopower58
Mopower58
CST is the Best!
71,028
650,683
Crystal Springs,Ms.
Because they are almost as old as Methusala!
They hide there walking canes well! 😂
1710897961216
Todd627
Todd627
56,446
616,512
MI
Well, ya fawkers are bad a bad influence , I dig it.
Elka stage 1,s orderd
I'm thinking just putting spare inside trunk dohickey , seems to be enough room.
Use a 25 inch stock front.
Oh and Pic dump
Good choice on the Elka Stage1’s. Best bang for the buck for suspension. Had Walker Evans on my P500 and they were awesome but, they were overkill. The suspension geometry of the P500/520 is limited and the Elka S1’s improve the ride as good as you can expect.
silvertrd09
silvertrd09
227
1,263
Texas
On an actuall half intelligent honda p5 note, how long does a full tank of gas last, normal riding
If you need a little more gas in the tank you can pull out the over fill protection thing, the white thing when you look in the gas tank. Supposedly gives you about 2 more inches of gas in the tank. On the spare tire, I put 26-9-12's on 4 front wheels. You could use either the front or rear wheel for a spare. And I'd do some kinda snorkel.
futzin
futzin
3,245
23,369
Kentucky
The Mudbusters (extra coverage) fronts do a great job, and look good, IMO.
Their approach to the rear is a bit different. They offer mud flaps; yeah they help. But they don't offer a rear fender flare like the fronts. Their approach is to offer two 3" plastic inserts that install between the fender and the main rear plastic piece (under the luggage rack). You end up with rear fenders that better cover the rear wheels. However, your plastics are now at 56" wide which can make the buggy look a bit odd from the rear (inset tires, wheels). And you'll scrape the fenders more on tight trails.
I have the full extra coverage set on my P500; they make a big difference. I'm running 27x11x12 tires on 4+3 offset wheels on the rear. I added 1" spacers back there to balance the look. It bugged me.
I don't have them on my 520 (same tire/wheel setup). It gets much muddier!
