Smart Carb
GovtMule
GovtMule
11,673
113,449
Tennessee
@HondaTech Any tips on cleaning out a bad gas Honda generator carb. The simplest approach is the best for me. It’ll sputter with the choke on, but won’t continue to run.
906UP
906UP
12,991
121,056
da Yoop
Your main jet (#24) and or enrichment tube (#14) is probably plugged......this may or may not be the carb you have, just a generic Honda gen carb schematic
Honda gx240 carburetor diagram 3
GovtMule
GovtMule
11,673
113,449
Tennessee
Those are finicky
It should have a pilot jet on top, it's plastic and the hole underneath needs cleaned as well.
Will it run with eco throttle off with no choke?
So it’s currently running with choke on and eco throttle off. When I try to take the choke off it dies. I do have some sea foam in the gas now…let it run like this and see if it will clear it up?
5,019
22,397
The choke has its own fuel circuit and it's running on that fuel. If the idle circuit is plugged (common with ethanol but not impossible with E-0), turning the choke off shuts off that fuel supply and it dies. Common in carbed, dual sport motorcycles. The idle jet has a really small orifice and plugs easily. Your mission, should you accept it, is to find, and clean, that jet. :cool:
GovtMule
GovtMule
11,673
113,449
Tennessee
Makes complete sense. If I knew where to look I bet I could find it!
5,019
22,397
There are like 4 parts in the carb, the jets are easy enough to identify. Remove them (or it) and make sure you can see through it. I soaked my pilot jets (smallest) in Seafoam overnight, it seemed to work pretty well. Some guys use welding tip cleaners but those will scratch the surfaces and alter fuel flow and can cause running problems. Squirt carb cleaner thru every hole and opening you can find, make sure it comes out 'somewhere'.
GovtMule
GovtMule
11,673
113,449
Tennessee
I think I can handle that.
