P1000 Solar panel??
O2bsmitty
O2bsmitty
298
658
Illinois
Maybe a crazy thought but for those of us that may use the pioneer for a beach stereo has anyone used a solar panel to help keep auxiliary battery charged when not running? Thinking about mounting one on top of hard top. Pros and cons please. Tia.
It could take several depending on the draw of the radio.
E
elkguide
3,377
7,964
Vermont
You'd certainly need a super shield for your roof mounted solar panel if you ever ride in the woods.
Reactions: O2bsmitty
Redone
Redone
107
305
wisconsin
57CC8790 BC7A 4A3F 8E70 7A3E57623B1A
E0819766 E0F5 4D4F 8D19 FFA20AE32300
DACBDFD6 3426 411A 9389 F8FAE30351D9
68CA6D9A 4342 4C3C B8EE C2C904EFBF97
Hey guy I know this is an old thread but I didn’t like that it seemed I needed to put my Honda on a trickle charge after every use. So I did just this I mounted a small solar panel on the roof and it works great now I have gone months without have to plug her in. And with how it’s mounted haven’t had any problems with low hanging branches it seems to charge while in the shop under my led shop light as well. Let me know what you think
JimmyA
JimmyA
1,644
5,504
Northeast texas
View attachment 161524 View attachment 161525 View attachment 161526 View attachment 161527 Hey guy I know this is an old thread but I didn’t like that it seemed I needed to put my Honda on a trickle charge after every use. So I did just this I mounted a small solar panel on the roof and it works great now I have gone months without have to plug her in. And with how it’s mounted haven’t had any problems with low hanging branches it seems to charge while in the shop under my led shop light as well. Let me know what you think
Nice!!!
Reactions: Redone
hacksawjoe
73
150
Mill Hall Pa.
Thanks even better solar panel costed me $0
hi ive got a 700-4 I mounted a solar panel on the rear flat portion of my roof put a regulator on under hood for spare battery it isn't wired into machine its just charged by solar use it for 52 in light bar and charging port for usb for battery spotlight had this for 1 1/2 yrs now no problem people see solar panel and ask about it
E
EmenAkpan
7
ca
Using a solar panel to charge your auxiliary battery for a beach stereo could be a convenient way to keep your battery topped up, especially if you spend long hours at the beach. However, there are some factors to consider, like the size of the solar panel needed to effectively charge your battery and the weather conditions at the beach. Also, mounting it securely on top of the hard top is crucial to avoid damage or theft. As for energy savings, have you thought about exploring solar options for your home as well? In Ireland, solar power is gaining popularity as a sustainable and cost-effective energy solution. It might be worth looking into solar ireland.
Jankyeye
Jankyeye
611
2,795
Tampa, Fl.
Holy thread resurrection.
108,207
Well done sir! You successfully used the search and dug up an old fossil! And about solar to boot! Must be a CA thing🤔
Im sure u knew this was coming….
No pics from you of your rig or even mention in any posts what rig yr make and model.
Please post some up or start an intro thread thanks bunches from the team😊
bumperm
bumperm
1,852
6,658
Gardnerville, NV
When camping in the Idaho wilderness with my Husky bush plane, I used a couple of flexible solar panels bungeed temporarily to the wing. Plenty of power to keep stuff charged. I mention this as it's an alternative to mounting them permanently on the roof where they would add weight up high. Easy to fold up and put away.
