Spec comparison for - Big Red vs Pioneer 700 vs 700-4
63,988
Here is a overview of the specs between the Big Red, Pioneer 700, and Pioneer700-4.
Overall there is not a big difference beyond the body style, the "long travel suspension" and the seating arrangement on the 700-4.
Quick break down of differences.
- Front and Rear Suspension
- Rear brake size
- Front tire size
- Over all size
- Turning Radius
- Weight
- Fuel Capacity
We do find it disappointing that the small 25" tire size on the OEM Big Red will transition to the Pioneer. You will also notice that the rear brake caliper is smaller on the Pioneer models vs the BR.
63,988
[parsehtml]<h2>Comparison between the Big Red, Pioneer 700 and 700-4.</h2>
<p id="content_nav"></p>
<p>Only what is highlighted is different between a model vs another. Most specs remain the same between all 3 units.&nbsp;</p><br />
<table summary="engine">
<tbody>
<tr>
<th scope="row">
<h3>SxS</h3></th>
<td><span style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px"><br />
<img src="http://powersports.honda.com/Assets/Models/2013_BigRed_145x90_Red_trans.png" alt="2013 Big Red" /><br />
<br /></span>
<h4 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">2013 Big Red</h4>
<ul style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">
<li>675cc liquid-cooled OHV single-cylinder four-stroke</li>
<li>Honda Automatic Transmission</li></ul>
<h5 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">&nbsp;</h5>
<h5 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">Starting at&nbsp;$11,699</h5></td>
<img src="http://powersports.honda.com/Assets/Models/2014_Pioneer700_145x90_HondaPhantomCamo_trans.png" alt="2014 Pioneer 700" /><br />
<br /></span>
<h4 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">2014 Pioneer 700</h4>
<h5 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">Starting at&nbsp;TBD</h5></td>
<td><span style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px"><img src="http://powersports.honda.com/Assets/Models/Category/Pioneer7004_380x372.png" alt="2014 Pioneer 700-4" title="2014 Pioneer 700-4" width="122" height="120" /></span>
<h4 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">2014 Pioneer 700-4</h4>
<li>2-3-4 Seating Configuration</li>
<h5 style="-webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px">Starting at&nbsp;TBD</h5></td></tr>
<tr></tr>
<tr>
<th scope="row" colspan="4">
<h3 align="left">ENGINE</h3></th></tr>
<tr>
<th scope="row">Engine Type</th>
<td>675cc liquid-cooled OHV single-cylinder four-stroke</td>
<td>675cc liquid-cooled OHV single-cylinder four-stroke</td></tr>
<tr>
<th scope="row">Bore And Stroke</th>
<td>102mm x 82.6mm</td>
<td>102.0mm x 82.6mm</td>
<td>102.0mm x 82.6mm</td></tr>
<tr>
<th scope="row">Compression Ratio</th>
<td>9.2:1</td>
<td>9.2:1</td>
<td>9.2:1</td></tr>
<tr>
<th scope="row">Induction</th>
<td>Fuel injection (PGM-FI), 40mm throttle body</td>
<td>Fuel Injection (PGM-FI), 40mm throttle body</td>
<td>Fuel Injection (PGM-FI), 40mm throttle body</td></tr>
<tr>
<th scope="row">Ignition</th>
<td>Full-transistorized type with electronic advance</td>
<td>Full-transistorized with electronic advance</td>
<td>Full-transistorized with electronic advance</td></tr>
<tr>
<th scope="row">Starter</th>
<td>Electric</td>
<td>Electric</td>
<td>Electric</td></tr>
<tr valign="top">
<h3 align="left">DRIVE TRAIN</h3></th></tr>
<tr>
<th scope="row">Clutch</th>
<td>Automatic</td>
<td>Automatic</td>
<td>Automatic</td></tr>
<tr>
<th scope="row">Transmission</th>
<td>Automotive-style with hydraulic torque converter; three forward gears and Reverse; three drive modes: 2WD, 4WD, and 4WD with all-wheel differential lock</td>
<td>Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock</td>
<td>Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock</td></tr>
<tr>
<th scope="row">Driveline</th>
<td>Direct front and rear driveshafts</td>
<td>Direct front and rear driveshafts</td></tr>
<tr>
<h3 align="left">CHASSIS / SUSPENSION / BRAKES</h3></th></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Front Suspension</span></th>
<td><span style="background-color: #ffff00">Independent double-wishbone; 5.9-inch travel</span></td>
<td><span style="background-color: #ffff00">Independent double-wishbone; 7.9 inches travel</span></td>
<td><span style="background-color: #ffff00">Independent double-wishbone; 7.9 inches travel</span></td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Rear Suspension</span></th>
<td><span style="background-color: #ffff00">Independent double-wishbone; 7.1-inch travel with adjustable preload</span></td>
<td><span style="background-color: #ffff00">Independent double-wishbone; 9.1 inches travel</span></td>
<td><span style="background-color: #ffff00">Independent double-wishbone; 9.1 inches travel</span></td></tr>
<tr>
<th scope="row">Front Brake</th>
<td>200mm hydraulic disc</td>
<td>200mm hydraulic disc</td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Rear Brake</span></th>
<td><span style="background-color: #ffff00">200mm hydraulic disc</span></td>
<td><span style="background-color: #ffff00">170mm hydraulic disc</span></td>
<td><span style="background-color: #ffff00">170mm hydraulic disc</span></td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Front Tires</span></th>
<td><span style="background-color: #ffff00">Maxxis Big Horn 25 x 10-12 bias</span></td>
<td><span style="background-color: #ffff00">25 x 8-12</span></td>
<td><span style="background-color: #ffff00">25 x 8-12</span></td></tr>
<tr>
<th scope="row">Rear Tires</th>
<td>Maxxis Big Horn 25 x 10-12 bias</td>
<td>25 x 10-12</td>
<td>25 x 10-12</td></tr>
<tr>
<h3 align="left">DIMENSIONS</h3></th></tr>
<tr>
<th scope="row">Length</th>
<td>114.7 inches</td>
<td>114.8 inches</td>
<td>114.8 inches</td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Width</span></th>
<td><span style="background-color: #ffff00">64.0 inches</span></td>
<td><span style="background-color: #ffff00">61.1 inches</span></td>
<td><span style="background-color: #ffff00">61.1 inches</span></td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Height</span></th>
<td><span style="background-color: #ffff00">76.9 inches</span></td>
<td><span style="background-color: #ffff00">77.6 inches</span></td>
<td><span style="background-color: #ffff00">78.3 inches</span></td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Wheelbase</span></th>
<td><span style="background-color: #ffff00">75.7 inches</span></td>
<td><span style="background-color: #ffff00">76.8 inches</span></td>
<td><span style="background-color: #ffff00">76.8 inches</span></td></tr>
<tr>
<th scope="row">Bed Length Inside</th>
<td>33.0 inches</td>
<td>Not Listed</td>
<td>Not Listed</td></tr>
<tr>
<th scope="row">Bed Width Inside</th>
<td>53.0 inches</td>
<td>Not Listed</td>
<tr>
<th scope="row">Bed Capacity</th>
<td>1,000 lbs.</td>
<td>1000 pounds</td>
<td>1000 pounds</td></tr>
<tr>
<th scope="row">Towing Capacity</th>
<td>1,500 lbs.</td>
<td>1500 pounds</td>
<td>1500 pounds</td></tr>
<tr>
<th scope="row">Ground Clearance</th>
<td>10.3 inches</td>
<td>10.3 inches</td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Turning Radius</span></th>
<td><span style="background-color: #ffff00">13.8 feet</span></td>
<td><span style="background-color: #ffff00">14.8 feet</span></td>
<td><span style="background-color: #ffff00">14.8 feet</span></td></tr>
<tr>
<th scope="row"><span style="background-color: #ffff00">Curb Weight</span></th>
<td><span style="background-color: #ffff00">1433 pounds - Includes all standard equipment, required fluids and a full tank of fuel-ready to ride.</span></td>
<td><span style="background-color: #ffff00">1261 pounds - Includes all standard equipment, required fluids and full tank of fuel?ready to ride.</span></td>
<td><span style="background-color: #ffff00">1396 pounds - Includes all standard equipment, required fluids and full tank of fuel?ready to ride.</span></td></tr>
<tr>
<th scope="row">Maximum Weight Capacity</th>
<td>1,690 lbs. (Includes weight of cargo, occupants, accessories, and trailer tongue load)</td>
<td>Not Listed</td>
<tr>
<th scope="row">GVWR</th>
<td>3,124 lbs. (maximum) Gross Vehicle Weight Recommended</td>
<td>Not Listed</td>
<tr>
<th scope="row"><span style="background-color: #ffff00">Fuel Capacity</span></th>
<td><span style="background-color: #ffff00">7.9 Gallons, including 1.5-gallon reserve</span></td>
<td><span style="background-color: #ffff00">8.2 gallons, including 1.2-gallon reserve</span></td>
<td><span style="background-color: #ffff00">8.2 gallons, including 1.2-gallon reserve</span></td></tr>
<tr>
<h3 align="left">OTHER</h3></th></tr>
<tr>
<th scope="row">Note</th>
<tr>
<th scope="row">Available Colors</th>
<td>Red, Olive, Natural Gear™ Camo</td>
<td>Red, Olive, Honda Phantom Camo™</td>
<td>Red, Olive, Honda Phantom Camo™</td></tr>
<tr>
<th scope="row">Model Id</th>
<td>MUV700</td>
<td>SXS700M2</td>
<td>SXS700M4</td></tr>
<tr>
<h3 align="left">FACTORY WARRANTY INFORMATION</h3></th></tr>
<tr>
<th scope="row">Duration</th>
<td>One Year</td>
<td>One Year</td>
<td>One Year</td></tr>
<tr>
<th scope="row">Description</th>
<td>Transferable limited warranty; extended coverage available with a Honda Protection Plan</td>
<td>Transferable limited warranty; extended coverage available with a Honda Protection Plan</td></tr></tbody></table>[/parsehtml]
