P500 Squeaks with weight in the back?
Dschaffer
32
81
Hey all. My P520 has a very annoying and almost constant squeaking sound whenever there is some weight in the dump bed. I would think it has to do with the suspension but it is almost like a moving squeaking, like it is connected to a rotating part. It can be heard while in gear and in neutral. Anybody else experience this and what is the solution? Thanks
The Green Goat
The Green Goat
1,808
12,917
Ohio
Yup. Pretty sure it's the brake rotor. Haven't tried or found any solution yet. It's on my list of things to address.
Reactions: trigger
crewcabrob
crewcabrob
1,029
4,038
Omaha
My bed will sometimes squeak on the rubber pads that are around the locking mechanism. I've heard some silicone spray helps quiet it.
I've had mine for a year and only have 379 miles on it, not much time to really spend looking for the squeak. Its either all business or all play when I get to start her up.
Dschaffer
32
81
I’ll check that out but I think its something to do with the suspension.
Reactions: crewcabrob
Sxsnewby
California
Mine had an annoying squeak as well. I put a little fresh grease on the area where the bed release latches are. Look under the bed when you have it lifted. There is a catch on each side and you can see where the latch rubs. Hopefully it is a s simple as mine was. Good luck!
N
NeHunter13
21
104
Nebraska
Mine does it as well. I think mine was coming from two different places:
1) The hinge pins at the back of the box where it connects to the frame of the machine. This is a metal on metal connection and on my machine was very tight. I had the box off so when I reinstalled the two hinge pins, I used some lubrication and that seemed to help.
2) The hooks of the dump lever where it connects to the box is also metal on metal and squeaks as well. Some lubrication there helped but didn't solve it completely.
