P500 Steel vs. Aluminum Wheels
futzin
futzin
3,113
22,387
Kentucky
Last year at Takeover, I had a couple of wheels sustain damage. Specifically, an outer rim/lip got bent in a couple of places (ITP steelies). No big deal, just cosmetic. My 500 is a trail rig, not a lawn queen.
My question: What sort of damage might an aluminum wheel have sustained? Many rigs have or come with aluminum wheels.
I'm toying with the idea of aluminum wheels on my 520 at some point. I won't mind the inevitable rash, but I'm concerned about harder hits.
104,950
They are fairly robust and hold up well. Ive had them on all 3 machines and havent had any issues like I did with the steel ones I had with that type of riding. The only negative is they scratch fairly easy depending on your riding style
155,558
When I switched out the stockers I had a couple of bent lips. Since I've been running the aluminum wheels I just see rash. They've held up pretty well.
5,018
22,390
The bead lock rings on my STI wheels are steel and take all the abuse, protecting the aluminum wheel itself. (This isn’t true, see correction below ☺️)
Back when they were new and pritty, not so much anymore. 😢
1679501256732
P
pappyo
593
2,377
ALL 4 Wheels 3rd..picture <> ITP 4×3 Offset 4×110 purchased Used 2009 ( Low milage ) With ITP- XTR Tires 27×9×12 ft. <> 27×11×12 6 rear. <> 6ply <> Depending on "load" <> air pressuer <> 6.5psi to 8psi
FYI: This picture shows how the sidewall helps protect the wheel.
ON - 3rd. Set of XTR 27's "On These Wheels"
A few minor scars / scratches / finish wear ( still in use ) & NO Wheel PROBLEMS <> did punctuer couple tires with sticks <> use as spares now
Above wheels on 3rd. SxS Now
1st on 2009 rzr ( with adapters )
2nd on 2014 Honda Pioneer P700-4
Now -3rd. on 2018 Honda Pioneer P500
These wheels have held up well Without any Problems Would Buy Again.
2nd picture both <> ITP Mudlite Tire & ITP Alum Wheel set up
1st. <> picture Kenda HTR's ( smooth ride with these ) on yamaha ( Alum Wheels 4 × 110 ) / "Not as Sturdy as" ITP WHEELS
2nd. <> picture <> ITP setup Described Above & still using today <> since 2009
3rd. <> picture All ITP TIRE & Wheel set.
All have been used in ADK Mt's upstate N.Y. with No Significant Damage.
Steel wheels <> show more lip damage than any of these Alum. wheels.
Alum wheels seem to taks glancing hits & scrapes better than steel.
Trying Alum. Beadlock's 12's <> on P520
20210607 082105 20200725 122406 20201114 111251
Ohio4x4
Ohio4x4
I brought the dishwasher
1,491
14,968
Ohio
My vote goes to aluminum wheels. More specifically beadlocks. I've bent steel wheels on trucks, jeeps, and atvs. I've never kinked a bead on an aluminum beadlock wheel. I've also never seen a steel wheel with a rock pushed through it either. There are pros and cons to both. I tell everyone beadlocks are worth the money if you are pushing the machine hard. If nothing else I've driven out of the woods with flats from rips in the side walls and the tires both stayed on the wheel when ran flat.
Dankathy
286
822
Sti hd9's can take a hit without breaking- to some degree. Many times with the jeeps a steel wheel has been hammered back close enough to kind of hold air to get us home, so there is that. I don't want to try that with aluminum
20230322 161510
Splorin
299
838
Maine
You can grenade ‘em all. Ball peen in tool box. Also have used rocks to straighten steel beads. Cast aluminum can take a good hit but also break and not bend. I have some of the old super lite ITP forged but they’re wrapped in 12” wides to somewhat protect them. I’m a poster boy for beadlocks but have never gone there. Tire bead protection probably helps a little. I’m on 4 fronts on 10s while pushing my luck…..
