P500 Stock rims?
ncred02
ncred02
1,031
1,769
Raleigh NC
So after some thought, I'm thinking keeping the stock wheels and just adding bigger tires. My kid made a good point. Why invest in wheels that we are going to beat on?
Don't know who's kid he is but it makes sense.
So what to buy?
Anyone who has done the same with great results give me your opinion.
Thanks
Reactions: Geoff
ncred02
ncred02
1,031
1,769
Raleigh NC
And I'm also concerned that bigger, as in height , may make it more unstable.
Any thought?
p500fan
p500fan
418
358
Sand Point, AK
As low geared as the P500 is, I'm not sure that it matters so much. I went bigger, with 14" aluminum rims, & cannot see a noticeable power loss. Larger tires also improved steering, as well as giving more ground clearance. I, too, was worried about stability, and ordered wheel spacers to widen my stance if it felt "tippy". I have since put over 200 miles of steep, twisty, loose gravel trails on it, and have sent the unused spacers back to the seller. As for accelerated brake wear, it's a small price to pay for the added benefits gained by installing larger, more durable, and more aggressive tires. Everything has a price.
Code54
Code54
583
626
Hurricane West Virginia
Im running 26's and have right at 12"s of ground clearance so the larger tires really works well for me. As for power I can't say I really notice any difference with the bigger tires, I do like the fact I can clear things I used to drag on.
Code54
Code54
583
626
Oh, as for brakes, I really don't think there will be much difference. With the gearing as it is I rarely use my brakes even here in the hills of WV.
Reactions: p500fan
p500fan
p500fan
418
358
Sand Point, AK
I can relate, Code54. I hardly use the brakes when riding. The compression/engine braking is one of the major selling points of these machines. The parking brake is used much more than the brake pedal. Ha!
G
Geoff
26
26
Falling Rock,W.V.
So what to buy?
Thanks
I just installed ITP Terracross tires on my stock rims to try and keep it as close to 50" wide. The front are 26x9x12 and the rears are 26x11x12. Took them on a short 23 mile ride today...had to drop to air pressure to 10 lbs in all tires to make the ride a little smoother....so far so good......
p500fan
p500fan
418
358
Sand Point, AK
How much wider are you now?
266,545
I'm looking at 26" x 9" 12" Roctane XD's on all four corners of my P500 mounted on stock rims.
Reactions: p500fan
