Stock wheels rubbing on A arm? And no brake or tail lights...
01Canes
64
372
53
North Idaho
  1. Talon X4
Not exactly what I was hoping to find, one of my front wheels has been rubbing on the a arm at full lock. Bad alignment? Toe out of wack? 60 miles on it.
Also, I noticed that I have no brake or tail lights. All fuses look fine. Where else do I look?
Not thrilled at all about the wheel.....
20230322 162815
20230322 162753
JenElio
JenElio
66,505
620,245
Loxahatchee, florida
Not thrilled at all about the wheel.....View attachment 380014View attachment 380017
Check your "toe".....although I don't know if it would have that much play.
The lights......maybe make sure all the plugs are plugged in tight....
Good luck
01Canes
64
372
53
North Idaho
  1. Talon X4
Good luck
Yea I looked at the toe and it appears that it may be toed out which would make it worse. Also noticed the exposed threads coming out of the rack are different by about 1/4" from side to side.
I'll check the plugs.
This is my 1st atv utv etc, is this par for the course or what?
906UP
906UP
13,309
124,813
da Yoop
I would guess your rack isn't centered. Turn all the way right, check clearance to the A-arm, then do the same on the left.
DRZRon1
DRZRon1
919
3,045
PA
don't trust anyone, check all your fluids as well, probably the wash boy was assigned to get one out the door and wack you $1k or so for dealer prep.....
sucks balls
01Canes
64
372
53
North Idaho
  1. Talon X4
sucks balls
Oh I know, I do all my own maintenance on everything because I don't trust anyone. Now onto my non functioning tail lights....
01Canes
64
372
53
North Idaho
  1. Talon X4
I plan on doing the 100 mile service soon, I'll have in the garage so I will be doing a thorough lookover and dialing in the toe. Stuff I should have checked already, but cmon what do these guys that don't know anything about stuff that buy these?
5,145
23,261
Check your sub trans fluid level for sure, both of mine were 1/3 low. :mad:
There’s a procedure for centering the steering rack, it’s listed in the New Talon Owners thread (Linked in my sig for those wondering)
Should probably measure your toe-in, not just set the threads the same. There a many reports of Honda completely messing up the original toe-in.
01Canes
64
372
53
North Idaho
  1. Talon X4
Funny you say that, my sub trans was leaking oil from the drain plug (but stopped). Pretty sure they over tightened it. But fluid level was fine.
I will for sure set the toe correctly when it's not sitting on an uneven gravel driveway 🤣
5,145
23,261
My trailer is a nearly perfect toe-in rack, the rails are about an inch wider than the sidewalls. Run one tire up against a rail, measure to the other. This is actually the wrong side, the gap is on the other side.
1679534368537
Like this -
1679534490269
