STV Motorsports Winch Switch wiring diagram
  • Thread starter Deleted member 3748
  • Start date
Deleted member 3748
Has anyone used the STV Motorsports 7-pin winch in/out switch? Mine came without a wiring diagram and it's going to take some time to figure it out.
63,541
How is it laid out. Can you snap a pic.
Guessing. 2 across top, 2 across bottom, and 3 in the middle.
Deleted member 3748
CLose. On the light switches 7 & 8 (top) are grounds. I'm guessing 7 will be a ground on the winch switch as well, 8 is empty.
8 7
1 4
2 5
3 6
IMAG00524
265,435
I've got a card with all the STV Switches pin layouts and I have that exact same switch let be snap a few pics.
265,435
Here is the Pin Out card that comes with all switches covers 3,5,6,7 Pin Rocker Switches. Also attached as a PDF of much easier printing/reading for later reference. See PDF attached at bottom for download much easier to read.
STV Switch Pin Out
  • STV Rocker Switch Pin Schematic.pdf
Deleted member 3748
STV just came through with a Saturday email with the same wiring diagram. Thanks for all the help guys. You just saved me several hours or work!
Reactions: Hondasxs
