Sub Transmission oil.
McCarthy
267
537
Canada
There's no oil pump in the sub trans, it's essentially a transfer case. Splash lubricated gears.
Tramguage1
Tramguage1
Texan
7,184
27,679
Somereset, Texas
I use my Talon strictly for short course racing in Texas. 10w30 motor oil is water on a summer day BEFORE I even run it and the subtrans is a known weak link. Having extra protection with a thicker fluid is key to its longevity in my opinion.
I also run Heavyweight Shockproof in the diffs even though a thinner oil is specified in the manual.
I can see in your application, just wasn't sure under the normal usage would need heavier oil.
Heck hit me up next time you run in Texas. Im in San Antonio, may come rute you on!!!
P1K5Dave
P1K5Dave
2,186
8,182
Petoskey, MI
If you live in a colder climate, heavier fluids in the subtrans can lead to issues moving into / out gears, I've read...
Reactions: CID
Killer223
Killer223
265
529
all these worried posts about engine oil in a t-case.
for starters the viscosity of the two are very close the 10/40 vs 80/90,
second toyota has been tuning motor oil in the t-case sense the early 90's. I sold my 93 with well over 600K and it only ever saw Napa 10/40 engine oil.
  • Wow
Reactions: CID and Smitty335
Robobrainiac
Robobrainiac
2,475
8,664
Imagine if they made atmosphere specific racing oils tuned to the environment!
Like 12W27
:p
