P700 Super ATV Flip Windshield Clamps Sliding Down
benelli_t
11
14
La
Guys, the clamps are tight but do not fit snug enough on the bar. The four clamps on the top portion keep sliding down. Thinking of wrapping double sided sticky tape on the bar then putting the clamps back on. Has anyone else fought this issue?
Backwoods
Backwoods
32,311
331,658
Douglasville ga
Did you use the rubber they send with it . I can put my weight on the clamp and they won't move.
benelli_t
11
14
La
Bought it used. Didn’t know rubber was suppose to be inside of it. This must be the problem then.
Reactions: SuperATV
Brmcg324
Brmcg324
51
199
SW Ohio
I use friction-type electrical tape for all of my ROPS clamps, easier than any sticky adhesive tape. Just put on a layer at a time and build up the diameter enough to give the clamp a good surface to lock solidly. Also easy to remove if you have a future reason to change it. You can get this at lowes or Amazon, it is very common and inexpensive for wiring harness wrapping such as in car engines where plastic adhesive tape will fail.
105,518
@benelli_t contact @SuperATV via a personal conversation and he will fix u up with some rubber for them clamps.
@craigs
Welcome fellow Michigander!
@craigs & @benelli_t
theres no pics of your machines on here yet And u both been members 6 months or more! 🤨
Pics Or It Didnt Happen! 😘🥳
benelli_t
11
14
La
Thank you for all the help guys!
