Talon 1000x clutch temp indicator and 83 DTC error
Daniil
50
76
Lithuania
Hello everyone, already 6 months I cannot deal with 83 error, tried new oil pressure sensors, checked wires, whore wiring cables, ground connections(2 on engine, 1 joint under driver seat) checked for corrosion, bad or loose contact, low voltage battery, nothing helped, does anyone have other ideas what to check, here is the video with error and clutch temp indicator.
108,256
Is it under warranty?
U said 6months assuming you've only had it that long?
Reactions: TxDoc and Smitty335
906UP
906UP
13,205
123,495
da Yoop
@HondaTech
Daniil
50
76
Lithuania
Hi everyone, the answer to all my discussions is the same, finally after more than half a year I fixed Talon, the problem turned out to be neither in the wiring, not in the ecm, not in the connectors, the problem turned out to be in 2pcs oil pressure sensors, they just periodically did not show the value on the signal wire, ordered the original sensors for 50$ from Japan, put and everything worked, thanks to all who helped and offered solutions to the problem.
5,099
22,929
Thanks for the follow up. 👍 You get the award for extreme persistence. :cool:
