Talon Axle nut size increased AGAIN!!! New hubs for 2023
63,705
We were pegging Honda on small changes not listed and this one came up.
For the second year in a row Honda has increased the Axle nut shaft size.
2024 = 24mm nut, 36mm scoket size
2023 (non s) = 24mm, 36mm scoket size
2022 (and 23 s models) = 22mm, 32mm scoket size.
2019-21 = 20mm, 30mm scoket size.
Also being told the 2023 (non s) has helical hub splines. So older hubs, including 2023 S models, are not interchangeable.
5,038
22,533
2023 (non s) = 24mm, 34mm scoket size
Are the axles interchangeable if replacement is necessary? (can I upgrade my 2021 to 2023 axles?)
56,797
Lol... Just picked up a 32mm socket for my trail tool kit the other day. Got to grab a 34 now...
P1K5Dave
P1K5Dave
2,175
8,130
Petoskey, MI
I'm a bit puzzled by these changes to axles. I haven't seen a single report of an issue with the older, smaller axle nuts around here.
Seems like Honda could focus their engineering efforts on things we're more likely to need - like injector plug wires on the P1000.
SLOWPOKE693
SLOWPOKE693
1,615
6,137
Somewhere in Texas
Mine used to move every couple races. I'd torque them to spec and install new cotter pins every time and in a few races the cotter pins would always look like Z's because the nut had moved.
HondaTech
They've had problems breaking at the splines when racing.
The injector crimp issue hasn't been a thing for awhile.
