I only made this 1 and ended up removing it , I think it may have robbed me of a little power!Looks cool! Do you have a link for this
As soon as it hits 40-42 mph , is when it will start to cut out.
Ya , I think each machine varies , mine cuts out at 41-42. Pretty sure they will cut out in any gear (not positive) , if you rev it high enough!That's odd, maybe all the speedo's are off a little but I can cruise 42 all day but as soon as it touches 43 the limiter kicks in.
Mine cuts at 40.That's odd, maybe all the speedo's are off a little but I can cruise 42 all day but as soon as it touches 43 the limiter kicks in.
I agree, the more I drive it, the more I like it.Work called off due to no water, not sure why...but really I don’t care because it gave me an opportunity to play with the P5 a little
Got the skids back on and noticed my cleaning job was not very good oh well give me a reason to make the run again on my next day off! Also threw some sea foam in her and let her run for an hour!
I took her through the woods around the house and tested her a bit. Idled through snow drifts and ran over small trees and the Mini-Beast didn’t even break a sweat!
Man...the more I drive the P5 the more I like it
Mine cuts at 40.
Mine at 39.Mine cuts at 40.
Mine at 64 !!!, and it is REDMine at 39.
Apparently the red ones aren't faster...
I got one of those for the 700, cut it up and reglassed it to fit the 1000. Box worked well but the speaker had massive distortion and fell apart quickly. Personally unless the amp and sub have gotten better Id see if you could find it unloaded and do your own equipment.
Couldnt agree more with you about the system being an addiction all on its own! I have been doing alot of research on the possibilities with the P5 and it is definitely more challenging than a system build in a P1000 so my hat is off to you! you have done some pretty cool things to get a great sound! Just got done watching and listening to some of your videos posted in Vulgar Displays of Power and its got me excitedI have some stereo changes in the works, CP's post about the pods got my wheels turning. It cranks already but now I'm going for better quality. I'm always thinking about the system, it's an addiction all on its own.
