They should build it.
320,493
Never seen a Red Warlock, all I ever saw was black but a Red one is possible I guess. I bought my Lil Red Express new in June 1979 and kept it for 17 years.
Warlock came in a few colors. Don’t remember exactly but I’d asked my father years ago and that’s what he’d said. He worked for Dodge back then and said everyone bought black. I’d figure one of the others now would be super valuable.
Reactions: Mopower58
Mopower58
Mopower58
CST is the Best!
71,030
650,727
Crystal Springs,Ms.
My Lil Red came with the E-58 police 360. A little higher stall converter with a special built torqueflite 727,340 camshaft 252 degrees duration w/33 degrees overlap,850 cfm thermoquad,dual snorkle fresh air intake from around the front parking lights,dual catalytic converters,dual 2.5 inch exhaust with HEMI mufflers and exhaust crossover,and a 9 1/4 Dana with 3.55 gears.
Reactions: Bigshow
Mopower58
Mopower58
CST is the Best!
71,030
650,727
Crystal Springs,Ms.
Had a 360 A engine with 340 heads from 68/69 and a 4 barrel carb. The 360 has a larger diameter crank shaft than the 340 so they don't directly interchange. The 360s of the 70's never ran as good as the 340 from 68/69 due to smog/emissions standards that started in 72. The last couple years of the 340 did not run like those first 2 years because of emissions/insurance policies of the early 70's.
In 1972 the 340 changed the camshaft,installed smaller intake valves from 2.02 to 1.88,and lowered the compression ratio from 10.2 to 8.5. My cousin runs a 73 340 Duster in Stock Eliminator.F/SA
IMG 1836
Reactions: Bigshow
