P500 This a problem?
The Green Goat
The Green Goat
1,870
13,572
Sooooo. Got the new WE shocks on front and rear, but I see a potential problem. The fitting coming off the rear shock body to the reservoir is pretty close to the frame. I can't mount it the other direction on the driver's side because the 520s exhaust is now straight and runs right next to the frame. So I'm only left with this choice. I tried compressing the rear suspension as much as I could to see if this fitting will hit the frame, and though I am fat, I couldn't compress it enough and look at the same time. I don't want to find out the hard way on the trail that it doesn't have enough clearance. I see most of the 500 folks mount it with the fitting on the other side but I obviously don't have that option.
Certainly WE would have tested this out first? Thoughts?
Driver's side
PXL 20220605 233519562
Passenger side
PXL 20220605 233537299
The Green Goat
The Green Goat
1,870
13,572
I think you'll be alright.
Famous last words. lol
I think he is talking about the nipple out of the shock head.
Yup.
Put your phone on video and then lean on it?
I need to eat a few more cheeseburgers first. Even jumping on it, I still can't compress it all the way. That probably won't be the case when I start taking it off some sweet jumps.
Also, looks like I'm going to have to pull them back off to adjust the preload. It sits about 0.75" lower in the rear than it did with the stockers. I bought a spanner wrench set from Amazon, but there's no way to get one in there to turn it, so, off they come. Plan is to compress the spring about another inch and hope that raises it up some more. Ideally, I'd like it to sit about 0.5" higher than stock.
HUCK
HUCK
1,047
2,316
ARIZONA
Driver's side
Passenger side
Put a ratchet tie down on it and crank it down .
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
cant you just rotate the shock so the nipple is on the other side? Have done that on trucks/Jeeps. May have to relocate the reservoir as well.
5,153
23,343
Since you have to take the shocks off to set the preload, you could remove one shock, remove the spring, reinstall w/o spring and pull down with a ratchet strap as mentioned above. This might let you get to 'hard bottom' and see if that nipple clears.
The Green Goat
The Green Goat
1,870
13,572
Nope. Nipple hits the exhaust.
The Green Goat
The Green Goat
1,870
13,572
I picture this going poorly for me, with the end result of me missing some teeth. I imagine that spring would need compressed a bit to get the nut threads to engage. I could be wrong, but it seems that way.
Brmcg324
Brmcg324
51
199
SW Ohio
The question is what amount of wheel travel would produce enough angle motion to hit the fitting. Maybe drive one wheel up on a ramp or rock with some wheel travel and stop there where you could look at how close the fitting is versus the frame. May be impossible to stop exactly where you could look at it. Trying to get an idea of that fitting‘s movement within the range of wheel travel. The short wheel travel of the 500/520 may be what saves this from hitting the fitting.
5,153
23,343
Good idea, this is how I checked to see if my tender springs were coil binding.
I 4fqvQFp XL
I 4Tvb4VR X2
The Green Goat
The Green Goat
1,870
13,572
Epiphany! I think when I unbolt the bottom shock bolt, I will lift the A-arm to see how high the mounting hole goes at full compression. Then lower the arm and pivot the shock to roughly the same angle. In my mind, this seems like it should work. No compression needed.
LilRedDonkey
LilRedDonkey
180
613
cheesyland
Driver's side
Passenger side
can you turn the passenger side so you only worry about one instead of both?
