Tie-down strap location
Swampdog
Swampdog
75
408
53
Forgotten Coast, FL
I just purchased a P500 but have not picked it up yet. Reading the Owners Manual, it shows to hook the tie-downs to the floor of the trailer.
My utility trailer floor is 58 inches x 118 inches and has anchor points along the trailer's railing that are two-feet above the floor of the trailer.
My question: Will it be okay to use the anchor points on the trailer's railing instead of having to add anchor points to the floor of the trailer?
(I have been trailering my Yamaha Grizzly using the the trailer's railing anchor points for 18 years with no problems)
Thank you in advance for your answers.
Reactions: JenElio and Isaiah
O
oldfortyfive
596
1,321
Illinois
I'd recommend you add some tie off points to the floor. It's better all around that way given how much heavier the P500 is. Otherwise you are anchoring it like the center of a trampoline.
nitzo
nitzo
521
1,105
East Coast, Florida
I tie mine like this. Only at unsprung weight points. Trailer tie downs as you can see are on the floor and also welded points on corners of trailer.
Tiedown
5,052
22,655
I like the unsprung attachment points, it allows the suspension to work. I hadn't seen your front to rear tire strapping idea before and it opened up my thought process. How long are the straps going through the wheels? - I have several 36" axle straps but their metal end loops won't fit through the wheel spokes. :(
If those yellow plates are just held in place with wood screws, I'd change that to through bolts though. I'd have no faith in wood screws in this application.
Reactions: JenElio
nitzo
nitzo
521
1,105
East Coast, Florida
If I remember right the straps are 48" and no the plates are not held by wood screws, I have bolts all the way thru with fender washers and nylon nuts on the backside.
Reactions: JenElio and CID
5,052
22,655
Thanks, Nitzo. 👍
JenElio
JenElio
65,111
609,348
Loxahatchee, florida
Welocme to the club!
I would try and get some anchor points made floor level. Always a better tie down. My 2 cents 🤷‍♂️
Post some pics when u pic it up 👍
Reactions: Swampdog
Swampdog
Swampdog
75
408
53
Forgotten Coast, FL
That is exactly what I did, added anchor points to all four corners of my utility trailer. Thank you everybody for your help.
I plan to do that, I'll also change my avatar and update my owner and membership status. Thanks again!
Reactions: CID and JenElio
JenElio
JenElio
65,111
609,348
Nice!
🤔 where's "the forgoten coast" ?
Reactions: Swampdog
Hondap5
Hondap5
20
58
Monroe nc
I got flush mount tie downs off amazon. Easy install and work great. One on each corner. Like 40$ for all 4.
5FDA422C 2BB9 4690 80F6 34D13D26AE12 B026D371 19C0 42CC B4DD FE2955DF6A34
