P700 Tim-700 build
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Just about got it the way I want it.
My 2018 700 Deluxe.
Honda hard top
Honda split windshield
PBR windshield extenders
Honda soft rear window
STI HD3 ATV Wheels - 14 Inch
Tusk Terrabite Radial Tires 28x10R-14
Can am Commander Shocks front and rear
Badland 3500 Lb Winch
HERTZ HCX 165 6.5" Speakers mounted in homemade boxes from 6" pvc end caps.
Alpine - Power Pack 180W amp mounted in glove box
Rock lights for dome lights
Magnetic phone holder on switch panel
Crossroads SXS switch panel
Vinyl Creator Reptile eyes for headlights
17" light bar
Mudbuster fender extensions and flaps
I'm sure I forgot some stuff.
20201030 155844 20201030 155929 20201021 133924 20201030 160028 20201030 160006 20201030 155947 20201101 124819 20201030 155905
L
lowrider
1,741
3,688
Idaho Panhandle
Hey Tim...with a couple tweaks that's pretty much what I want to do to 700-2. You're an inspiration...CB, gun rack and a few other things! I just need to figure out what to do with the back roof and side walls.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Only downfall so far for me is I have to let the air out of the tires to get in the garage, will have to figure out some way to ratchet strap it down in the back to get in the garage.
L
lowrider
1,741
3,688
Idaho Panhandle
Not a problem for me garage wise it's full of motorcycles, ATV's and my wife has some silly notion she can get her Xterra in there...ain't gunna happen.
Do you have any plans to extend your roof rearward? I have unrefined ideas to put an aluminum roof on the back and some sort of sides, probably some alum frame with Lexan windows on sides and a lift up door on the back. I'd like to have weather tight storage in the back. Hard body seems difficult with that design due to flexing of the frame so I may just put in a small tool box or two back there. Need to get a machine first...shipments from the far East look like they may be late Winter or Spring per the dealers.
L
lowrider
1,741
3,688
Idaho Panhandle
If you come up with a good plan don't be afraid to share.
Reactions: Isaiah
Headhunterf100
Headhunterf100
60
106
Virginia
  2. Do not currently own
I was thinking about making a aluminum roof, I think I would be able to get in the garage then.
Down fall to an alum roof would be heat soak, unless you put some kind of heat barrier or lizard skin coating on it i fear it would cook you on a hot day of riding.
Reactions: Isaiah
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Wouldn't it be close to the same with the black plastic roof that is on now? Or does aluminum hold heat more?
Reactions: Isaiah
WagginTail
WagginTail
1,484
5,482
SC
My 2018 700 Deluxe.
Honda hard top
17" light bar
View attachment 233339 View attachment 233340 View attachment 233341 View attachment 233342 View attachment 233343 View attachment 233344 View attachment 233345 View attachment 233346
Nice set up. What is your wheel offset?
Reactions: Isaiah
