Tire/Wheel Combo Question
Cestratton
52
183
Harrison, AR
Just put a deposit on a 21 1000r Live Valve. I'd like to run a 30/9.5r15 or possibly a 31/9.5r15 Nitto Trail Grappler SxS. What offsets and backspace do I need to be looking for front and rear? I haven't narrowed down a particular wheel yet but thinking Method or KMC.
Thanks!
Reactions: TripleB
Cestratton
52
183
Harrison, AR
If I went with a 4/3 what spacers would I need front and rear? Ideally want to be able to rotate the tires and have an even stance front and rear.
Reactions: ChadD
PaulF
PaulF
1,462
4,810
  • X+Y advertised measurements are not accurate and completely meaningless.
  • Try to maintain stock front geometry as much as possible for best steering. You can do that by...
    • Use ~+50mm offset front wheels and ~+10mm offset rear, this will make you even front/rear.
    • OR use ~+50mm offset front and rear without spacers. You will be about 3" narrower in the rear.
    • OR use ~+50mm offset front and rear with 1.5" spacers in the rear to even it up if you prefer.
  • CAUTION: Some 14" wheels will rub and you may need to trim the upper control arm ends for clearance when using 14" wheels.
  • NEVER put spacers on the front.
Cestratton
52
183
Harrison, AR
Thanks! I'll be doing 15" wheels just wanted to be able to rotate all four corners and run 9.5 front and rear.
Reactions: ChadD
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
5/2 with 1" front spacer and 2" rear?
You won’t like what wider offset front wheels (or spacers) do to your bump steer and overall steering effort.
Use Paulf’s recommendations.
IE 6-1 offset wheels and 1 1/2” spacers in rear. (Like he said though the “50mm offset” number is more accurate than “6-1”)
PaulF
PaulF
1,462
4,810
Then I will update my suggestions...
    • Use ~+50mm offset front and rear without spacers. You will be about 3" narrower in the rear.
Cestratton
52
183
Harrison, AR
Who makes a good beadlock 15x7 with ~+50 offset? I see several +38 and 0. Also what's the deal with 4x136mm and 4x137mm seems like everyone says either will work, is that correct?
toddvdh
toddvdh
1,079
7,124
Green Bay, WI
I have 31x9.50x15R ITP ultra cross tires on bead locks with 1” spacers in the rear. I’m not sure what rims I have but they don’t rub. It’s kind of nice to have 5 rims and tires that can go on any spot.
4C604D6E 88EC 425D 8CBC 5EC355A41FA2
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
Those are STI HD9 bead locks, they appear to all be the same offset but of course I cant tell for sure from here. When you have a wheel off the rig you'll be able to see that info on the inside.
PaulF
PaulF
1,462
4,810
+38 mm offset will work but I do not recommend anything less than that.
You can use either 4x136 or 4x137.
Cestratton
52
183
Harrison, AR
If I went with +38 how much rear spacer would I need to have close to factory stance? I'm guessing 1"?
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I had trouble finding +50 in 15” also.
So I went 14”….
Reactions: ChadD
Joe_none
60
224
NC
If you are changing tire size @PaulF made additional offset suggestions in another thread:
The scrub radius changes with tire diameter. Stock wheels are +50mm offset and stock tires are 28" diameter. To maintain the same scrub radius with different sized tires you would need...
  1. 30" tires with a +47 mm offset. No such thing but there are +45 and +50 available.
  2. 32" tires with a +45 mm offset.
  3. 35" tires with a +41 mm offset.
6-1 verses 5-2 wheel spacing
Post#2
Reactions: CID and Cestratton
Cestratton
52
183
Harrison, AR
So I ordered a set of Method MR401 15x7 +38, Nitto Trail Grappler SxS LT30x9.5r15, and High Lifter 1.5" spacers for the rear. Sound like a good setup? What do I need to do for lug nuts? Spacers have 12mm x 1.5 thread pitch studs, will factory lugs work? Wheels are 60 degree conical seat.
Reactions: ChadD
PaulF
PaulF
1,462
4,810
That will be a great setup.
You will probably need small hex or spline drive lug nuts because the holes on many of these wheels are small and the socket for regular lug nuts doesn't fit.
Not sure about nuts to hold the spacers to the hub, maybe someone else will chime in on that.
Cestratton
52
183
Harrison, AR
The spacers come with nuts to attach to the factory studs.
Cestratton
52
183
Harrison, AR
Ok so wheels are on backorder but tires are on their way. I'm considering canceling the wheel order and keeping factory. With that said running 9.5 wides all the way around on stock wheels, other then the obvious 1.5" rear width difference from stock tires, what differences would I notice in handling, performance, and track width? I've tried researching and can't find much. Truck wheels and tires are so much more simplified lol.
PaulF
PaulF
1,462
4,810
The TRACK width will be unchanged, the OVERALL width will be 1.5" narrower in the rear, you will be fine.
One thing to be careful about is the rear rims with 9.5 wide tires will be more susceptible to damage because they will have less tire sidewall protection.
Reactions: Lil_Steve
